Hello fellow millplus owners,
I have a problem with a DMU80T Phillips controller.
After a spindle bearing replacement and parameters lost and restored the spindle is not spinning faster than 18rpm.
At around 15rpm the tool clamp icon is blinking, at 18RPM the tool clamp stays lit and at more than 18rpm I get the folowing error:
E102 prog. "S" > max.diameter of tool millplus error
After some work on it I discovered that the tool clamping sensor do nothing.
I completely disconected the plug with the two inductive sensors tool clamped and tool unclamped and the machine is not trowing any error. the plug also has a PTC for temperature in it.
So first question: Any ideea what can be done with the error thrown?
Scond: Anyone knows how could I acces the I/O page of the PLC(if such exists) to verify the machine sees those sensors or not?
Thank you
