586,058 active members*
3,889 visitors online*
Results 1 to 7 of 7
    Jan 2016
    99
    vfd fault code
    Anyone get a hf26 code on the 1100 vfd. Occasionally my spindle won't start until I turn off the panel key for about 30 to reset it. My manual has a hf 29 code. Maybe I missed it though.
    I contacted Tormach and they told me to check the braking resistor and for any loose connections. The connections weren't loose but the screws did move slightly. The resistor measure 75 ohms, right where it should be.
    It doesn't stop or slow down as in a previous post I read, just doesn't always start. Manual or automatic.
    Dave
    Sep 2016
    16
    Quote Originally Posted by toyshop View Post
    Dave
    Is this a 1100m? If so check resistor temp while spindle is running.
    Jan 2016
    99
    Re: vfd fault code
    Plain 1100 upgraded pathpilot control, 6 years old I think.
    Bit cold here and didn't feel like warming the shop up all the way today to run it for a short time.
    Dave
    Oct 2008
    21
    Re: vfd fault code
    I get the hf26 code on my series 2 1100 vfd on an intermittent basis. I called Tormach when it first happened a few months ago and they said replace the VFD. So since it is intermittent and I do not want to buy a new VFD I just put up with it. Maybe I get it once a week and power off the cabinet, watching for the VFD display to go dark, then power back up. Very annoying.
    My 9 year old 1100 is in a basement shop so it is not cold, seems to be happening randomly.
    So as soon as I start up the machine I check immediately if the spindle will turn rather then executing the referencing of X, Y and Z which has to be repeated if you have to power cycle the cabinet. Once its good it seems to stay that way.
    Sep 2009
    624
    Re: vfd fault code
    Quote Originally Posted by Jerry McFarland View Post
    deleted, didn't see your follow on about PP.
    Dec 2008
    740
    Re: vfd fault code
    My vfd doesn't report any faults but HF26 is described in the manual as:
    Soft start relay failed to close, or soft start monitor failed, or braking IGBT short circuit at power up.
    Not very specific!
    Step
    Jan 2016
    99
    Re: vfd fault code
    I took to checking if it starts also. Annoying but not enough to replace it yet.
    Getting at the terminals to check the resistor was a pain at the bottom of the cabinet and me hanging over the table.
    I ended up unscrewing it so I could see the connectors. I would have been easier if it were mounted near the top.
    I didn't have to power all the way down, just turned off the key on the front panel for about 30 seconds.
    Dave
  1. UNKNOWN FAULT CODE
    By CNC_BOB in forum OKK
    Last Post: 11-18-2022, 07:57 PM
  2. . Huanyang vfd e.ou.n fault code
    By Cncmachine2 in forum Spindles / VFD
    Last Post: 06-20-2018, 02:26 PM
  3. PM85 with fault code 0-52
    By francis_liang in forum Hypertherm Plasma
    Last Post: 06-17-2016, 06:26 AM
  4. Fanuc 11M Fault Code SR 820 DR OFF (1)
    By wemr449 in forum Fanuc
    Last Post: 04-10-2015, 08:41 PM
  5. Fault code
    By Rufan in forum Bridgeport / Hardinge Mills
    Last Post: 09-28-2005, 01:57 AM
