586,069 active members*
3,356 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > LOADING PARAMETERS INTO CONTROL 0-MB
Page 1 of 2 12
Results 1 to 20 of 24
    May 2014
    174
    Dear friends,
    So far we have tried every possible way to reload parameters after a main board replacement. Sadly we have not been able to do so, because the control will not allow us to INPUT none of these parameters. Not even the 900 group. The only value we can input is TOOL OFFSETS.
    One thing I have noticed recently is what I am showing on the attached pictures. The new board does not show the bottom line. I wonder if anyone here had gone through the same scenario and found a way out. It´s been weeks already since this machine went down on us. We will appreciate any help.
    Flex.
    May 2016
    526
    Re: LOADING PARAMETERS INTO CONTROL 0-MB
    Is your parameter write switched on ?
    May 2014
    174
    Quote Originally Posted by mbservice View Post
    Are you referring to this keyed switch labelled as "Program Protect" in our machine? (see picture)
    Apr 2017
    9
    No
    In second page of parameters you have :
    Put pwe to 1 to unlock
    Envoyé de mon iPhone en utilisant Tapatalk
    May 2014
    174
    Quote Originally Posted by olivc View Post
    No
    Yes it is.
    Apr 2017
    9
    You have to input 900 parameters in manual
    It do procedure to restore parameters but it’s un french, if it can help you
    Apr 2017
    9
    For the bellow of menu, it’s certainly diagnostic parameters about manufacturer
    On my supermax, i have to input 900 parameters and some diagnostics parameters
    Apr 2017
    9
    You have alsow to open program protect key to enable dnc prog input
    May 2014
    174
    Yes. Problem here is that our controller will not allows us to INPUT any parameters at all. so we cannot load 900 parameters manually. We have tried everything we know, but like I am pointing out on my original post, what´s very suspicious is the missing bottom line of characters in the screen. We believe that is some good indicators of something wrong with the code. EPROM, MEMORY, FIRMWARE? We don´t know.
    Apr 2017
    9
    For me missing Line is diagnostic config.
    Do you have a save of diagnostic?
    When you put pwe=1 (in imd) you have an error ?
    Apr 2017
    9
    Normely to modifie parameters in manual on 0m, you only have to put pwe to 1
    Nov 2012
    145
    Isn’t the switch in the electrical cabinet
    Feb 2012
    126
    The botom line is likely missing as the softkey menu must be enabled by a paramater. On the zero it's an option.
    May 2016
    526
    No it sounds like your parameter write enable is switched off
    What control is that
    Apr 2009
    1379
    it says right in the heading: CONTROL 0-MB
    PROGRAM PROTECT key is immaterial for parameters.
    PWE is 'ON'
    He has no sub-cpu
    Masterboard has been replaced: no difference
    Jan 2006
    61
    I'm wondering if the machine may be in hard overtravel. If so, you must keep the OT bypass and start button pressed while you manually input the 900's. The screen that doesn't have the bottom line is indicating MDI mode.
    Dec 2009
    953
    can you say if diagnose X 21.4 is 0?
    May 2014
    174
    Quote Originally Posted by zavateandu View Post
    Yes. It toggles between 1 and 0 whenever I activate E-Stop PB.
    May 2014
    174
    Quote Originally Posted by tom o View Post
    Hello Tom, To be honest, I have not looked so widely for a switch. I had no idea there could be one but I do not discard it at all, since this is a mill from 1986 that even has a TAPE READER unit. which of course we do not use. It looks like a piece of museum. Thanks for the heads up! I will let you know if I find something,
    flx
    May 2014
    174
    Quote Originally Posted by regina View Post
    Hello Regina. That´s very interesting! and please tell me, how to get to that parameter and what´s the proper procedure to change it and enable softkeys? Thank you!
Page 1 of 2 12
  1. Loading parameters on 18M control
    By peloflex in forum Fanuc
    Last Post: 04-13-2017, 03:09 PM
  2. down loading parameters 18M
    By TurboCare in forum Fanuc
    Last Post: 01-01-2016, 09:53 AM
  3. loading parameters help please!
    By KyleEnright in forum Daewoo/Doosan
    Last Post: 10-07-2014, 07:44 PM
  4. UP loading parameters to the 5T
    By Paul Pippenger in forum Fanuc
    Last Post: 01-21-2009, 09:27 AM
  5. Replies: 12
    Last Post: 10-20-2008, 08:30 PM
