586,119 active members*
3,603 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Mach 3 quit reading machine end stops.
Results 1 to 6 of 6
    Oct 2008
    18
    I did something, but I don't know what. Yesterday when I was messing with my Pro2448 all was well. If I hit an end stop Mach 3 read it and stopped travel as it should. Today, not so well. I'm setting machine zero and when I go to and end stop, the light on the sensor lights up as it should but Mach 3 ignores it. Obviously I changed something someplace but I don't know what. Any ideas?
    Apr 2004
    5737
    Re: Mach 3 quit reading machine end stops.
    In Config, check the Ports and Pins/Input signals dialog. There are settings for home switches on each axis there. If they aren't enabled, enable them. Try changing one from Low Active, or to it if that's already checked, and test to see if anything changed.
    Andrew Werby
    Website
    Sep 2005
    1740
    Unless you changed those pins in a setting somehow I would not mess with. It was really cold in the shop this morning and I had a fault with the ESS controller did not boot up or something. I let it set for a while and reset and tried again all was fine. Maybe the machine being too cold made it fault out??
    Aug 2018
    59
    Try this. Go to the settings tab in mach 3, in the column for special functions make sure the button to over ride the limits is not checked. I had that happen and that was the problem for me.
    Oct 2008
    18
    Strange. Today it all works. Not sure what I did to fix it but I guess that's OK, I,m not sure what I did to break it. When it broke nothing (that I know of) was changed. I hadn't even been in any of the config or setup screens. In fact, all I did (that I know of) was load a new profile. I did try a few things to fix it yesterday (checking that all the sensors were being read by Mach, messing with the settings in the setup tab) but nothing seemed to work. I hate when this happens. By the way, the auto Z didn't work either, even though Mach was reporting all of the sensors working. Thanks for the input.
    Jun 2010
    4256
    You might like to check the actual connections into whatever BoB you are using as well.
    Cheers
    Roger
  1. Mach 3 stops mid cut
    By tjb1187 in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2022, 10:30 PM
  2. Mach stops randonmly
    By bcer960 in forum Mach Mill
    Last Post: 11-01-2016, 02:33 AM
  3. Mach 3 stops responding during cut
    By Jason Marsha in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2014, 02:48 PM
  4. mach is reading things backwards
    By cob in forum Mach Mill
    Last Post: 04-04-2010, 05:36 AM
  5. Mach 3 not reading 0.000 at home switches
    By hindocarina in forum Mach Mill
    Last Post: 11-18-2008, 12:04 AM
