586,388 active members*
3,385 visitors online*
Page 6 of 7 4567
Results 101 to 120 of 130
  1. #101
    Mar 2017
    250
    Re: 4th axis touch probing
    There is much more code than I thought at first. You must have didn't some time in this. Now I wish I stayed home today. I won't stop thinking about trying this until I can.
    Sent from my SM-N950U using Tapatalk
  2. #102
    May 2015
    1422
    Yeah threw another couple hours at it yesterday - as well as the probe tips. But I'm happy with it now.
    FWIW once I'd run this, I then jogged to just over my tool setter probe (the simple puck with the alligator clip) and ran a G31 Z-100 F20 which stopped on top of the puck. I took the -ve Z reading and set that as my gauge height. Now I can load a tool, run the auto tool length (whose macro was the basis for this!) and now Z=0 will put the tool tip on the A axis.
    Just be careful - if you're like me and normally run Z=0 at the top of the workpiece, you'll need to remember that the "+ve Z = safe to travel" mindset will not work here.
  3. #103
    Jun 2010
    4256
    Um ... why not? (I am assuming that +Z is still upwards.)
    Or are you thinking about sideways collisions?
    Cheers
    Roger
  4. #104
    May 2015
    1422
    Yep - normally I have Z touched off at the highest part of the workpiece, so any sideways move with Z not negative is safe - worst, it'll scratch as it kisses at z=0.
    With this setup, Z = 0 at A axis, so sideways (well, Y front to back moves) will collide if Z < radius of the workpiece.
    Obvious when it happens, and a warning against complacency of assuming Z safe heights instead of perhaps specifically setting them per setup.
  5. #105
    Jun 2010
    4256
    Ah - A axis. Right!
    Cheers
    Roger
  6. #106
    Mar 2017
    250
    Quote Originally Posted by dharmic View Post
    Sorry I was wrong. I actually never pressed ok, only hit enter on the keyboard after entering the diameter. It moves after hitting ok. Hitting enter closes the form and then nothing.
    I started playing with this and I am not sure what I am doing wrong. When I call the macro I get prompted for the radius, I corrected this to say diameter in the code because it looks as though it divides the entered number by 2, I enter the number and press ok. Nothing happens, so I reset because I cannot move and the script never completes.
    Is there a way to step through and debug in mach? I cannot figure out what is happening. Seems to run right up until the diameter is entered.
    thank you for the help and any more you can provide.
  7. #107
    Mar 2017
    250
    Ok, I have your script working perfectly now. You reference the auto tool length macro in the post. Which one are you using? I am trying to find the one you mentioned, but I'm not sure which. So many that people post out there.
  8. #108
    May 2015
    1422
    Apologies for the misleading prompt - it started as radius but then I realised I was doing the mental divide-by-two from what came off the micrometer and that there was a thing called a computer sitting in front of me capable of doing that complex math I just forgot to update the prompt.
    What was causing the stall? I do find if I hit <Esc> on the keyboard instead of <Enter> from the MDI window to allow jogging instead of g-code entry, it can stall motion and cause all sorts of confusion.
    Tool probe macro came with the machine. Essentially it's a G31 to current Z minus 100mm, could use the Approach routine for that. Then it backs off 5mm and sets Z to whatever is set as the gauge height + 5mm.
  9. #109
    Mar 2017
    250
    It didn't really stall or stop my controller. It just didn't do anything and I just got the reset button and started over. Not the full program. Didn't think of hitting escape. I'll try that. I know it works during the routine.
    My probing routine is from CNC router parts and sets zero. I'll look around for a tool probing routine. I'd like to add it to my m6.
  10. #110
    May 2015
    1422
    Sorry, to be clear, my issue with no movement usually came from me having hit escape beforehand. It put it in some kind of panic no-movement state. Hitting it again clears that state from what I've seen but leaves things a little messed up if you've already started the macro.
    My probe routine also sets z=0, it doesn't play with tool length offsets or anything like that. Doesn't seem like there's a lot of point in a machine without toolholders.
  11. #111
    Mar 2017
    250
    oh. I see now. Yes, hitting esc does do that, hitting enter did a similar thing. But, this morning I tried both to verify and this time enter actually worked. No idea how it had 2 different behaviors. It does not matter though, I just need to hit ok instead of any keys.
    what does ve stand for?
    I guess I was thinking that the touch off with the tool would set the touched tool length so that z0 would account for the difference. If I were using the table, when receiving an M6 it would move to my tool change position and wait until I ran my auto zero with the new tool and then go back to the next path.
    Your script is great and I really thank you for helping with it. It makes me feel that I can at least actually know where my center is. Before, it was much more work when putting my 4th back on the table. I had the math written out so that I could just enter my numbers after attaching it and it was pretty good. But being able to verify the location after the math makes me more comfortable with it.
  12. #112
    May 2015
    1422
    ve?
    Happy to share - turns out I needed it myself last week so thank you for promoting me to write it up.
    Agreed, makes thing a lot nicer and more comfortable putting the 4th into play!
  13. #113
    Mar 2017
    250
    In this context, I attempted to search and found nothing. You reference several times through the thread as well as in the code. I just do not know what it means.
  14. #114
    May 2015
    1422
    Ah: shorthand for positive +ve, negative -ve etc.
  15. #115
    Mar 2017
    250
    sorry, im trying to figure out what ve is. You are obviously much more schooled in mach3 than I am. What does ve stand for? again, sorry I am such a noob.
  16. #116
    May 2015
    1422
    Per my last post mate. Nothing to do with Mach3 and I'm a n00b there too. +ve, -ve are pretty common abbreviations where I've come from.
  17. #117
    Mar 2017
    250
    Ok. I just don't know what the abbreviation is for. It could be anything, vegetable elephants for all I know. Thanks for responding though.
  18. #118
    May 2015
    1422
    I just told you twice man. Nothing to do with Mach, it's in a comments. "ve" is just the sound at the end of "positive" or "negative". +ve is shorthand for positive. -ve is shorthand for negative. "ve" doesn't appear on its own.
    Your eyes and brain are stuck in the wrong gear now, that's happened to me enough times so I get it. Forget about it, it's just a comment. Come back and read this post again tomorrow after a break. Then have a look at the source code again. And you'll go "Oh. is that all?"
  19. #119
    Mar 2017
    250
    You're right. Over thinking it. I'll just think of it as positive and negative. It works and that's all I really need. Now that you've blatantly stated it 3 times, I get it.
  20. #120
    Mar 2017
    250
    I can't believe how stuck I was in that. Just needed to tell you that. It's weird how I could not get it and how incredibly simple and straight forward the 3 replies were. Every time I think about it I feel dumb now.
Page 6 of 7 4567
  1. Axis jog through home switches. How to configure?
    By Ricc in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2019, 02:35 PM
