586,061 active members*
4,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 Realtime CPU Board BIOS 2a5led42
    Tengo una cnc arrow 1000
    tengo cnc cincinatty arrw 2100 el cual presento error de rt
    se le cambiaron filtros a la board
    se le coloca otra board y la maquina trabaja bien
    mi pregunta es?
    alguien tiene la configuracion de bios de esta board rt
    es una board g7vp2 con bios 2a5led42
    daba error de rt y error de servo, estos ya fueron solucionados
    hay posibilidades que sea la bios o la configuracion de la misma que este bloqueando la bridge (rack 0)
    gracias
    Dec 2006
    584
    Re: Acramatic 2100 Realtime CPU Board BIOS 2a5led42
    ENGLISH ENGLISH ENGLISH !!!!!
    Mar 2008
    285
    Paquiro,
    The RT-CPU board on the right side has a "3-424-xxxxAyy" part number on the Barcode Label on the lower inside lip of the metal board chassis.
    You cannot change the battery on this board unless the board is on a bench under power without losing the BIOS Settings.
    The Bios on these boards is Flashed in using a Floppy disk with a binary parameter file. Fives-MSI Cincinnati charges $350 USD to
    Replace the battery; Flash the BIOS Parameters; Test the board in a Simulator with a special I/O Tester Board Assy.
    It normally takes 1-2 days once we receive to board to do this.
    The WS-CPU board on the left side has a "3-424-xxxxAyy" part number on the Barcode Label on the lower inside lip of the metal board chassis.
    The Bios on the WS-CPU board can be re-entered with a PC style keyboard. The settings are in the Control Reference Manual or we can email them to you.
    Our Tech Support Phone number is 01-859-534-4750 8am to 5pm EST (Lunch Noon-1PM EST) No hablo Español
    Greg Wood Fives-MSI "Cincinnati" Hebron, Kentucky USA
    Sep 2008
    100
    paquiro 99 If you need support in Spanish, I can help you ... contact me
  1. Replies: 2
    Last Post: 01-25-2019, 10:56 PM
