586,361 active members*
3,327 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Ocuma lb15 OSP 5000-LG 980 Fault-c panel/crp receive 8 !!!
    Apr 2015
    45
    Hello,
    All started yesterday, when i turned on the machine in the morning. I started the program, and the work speed was very low not normal on x and z axes. I mean the drilling speed was decreased twice. So i called our company electrician he started to look through % switcher on control panel. But then he found some short circuits on CPR board and fixed them (replaced some components on board or smth). After that our machine started to not fully load, when the machine boot's up we got an error with message cpr problem. Then the electrician took out the board again did smth. and now machine boots up olmoust normaly, but not all buttons working and we have the error now 980 fault-c panel/crp receive 8 . Maybe someone can give us advise where to look for smothing? We tried to look from forum's about this problem we stuck now.
    i upload some photos.
    Apr 2020
    Re: Ocuma lb15 OSP 5000-LG 980 Fault-c panel/crp receive 8 !!!
    Hello! Same problem with my machine! What was the cause of the error? Thank you in advance for your help!
    Aug 2011
    419
    Firstly check optical cables
    "Imagination is more important than knowledge."
    Apr 2020
    I did not find an optical cable in the wiring harnesses. What kind of optical cable do you mean?
    Apr 2009
    1262
    The optical cables did not start until the 7000 control so that will not be your issue. Your receive error indicates a communication problem between devices such as a loose or missing cable or poor connection. Double check cables for proper installation. If placement and connection is good try to determine which board is having trouble communicating and check circuits for damage or faults. Usually connection is the issue. After nearly 30 years some corrosion can occur.
    Best regards,
  1. Replies: 16
    Last Post: 01-22-2019, 09:34 PM
