Hey there!
Ok so i know that the x2 is never going to move material crazy fast, or be crazy rigid, but I do know a solid base helps a ton! So right now I have a bunch of 3in steel tube stock with 1/16th" in walls, and on its own, the stuff is really rigid, welded together it should be pretty heavy as well. However the base is not currently built and I had the idea to fill the tube stock, maybe just the legs, with sand to help really deaden the vibrations. I have a strong feeling it will help, but i'm not sure where the point of diminishing returns is in regards to a base.
Anywho, just wondering if anyone thinks this might be a worthwhile thing to try out or is it way too much given the restraints of the machine itself?
Best,
Dave
