586,055 active members*
4,176 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Metalworking- / Woodworking Tooling / Manual Machining > advice on chipping and milling quality with 8mm bit on 10mm plywood
Results 1 to 18 of 18
    Aug 2017
    31
    I'm milling a profile cut full depth on a 10mm plywood piece.
    I'm using an 8mm, 3-flute endmill, downcut.
    My settings were:
    16000 RPM
    5mm/sec feedrate
    A few things in the attached images are clear to see:
    1 - some of the paths generate a "twirly" piece of chipping. Why is that?
    2 - The finished quality is not good. There are chipped off parts at the surface. It looks like what an upcut should do, but I have a downcut. What causes this effect?
    3 - The plywood get's darker as it burns, which is not something I want.
    During the milling, my RPM was too low and the axis "lagged" by about 5mm, so I had to restart the Z position because the bit was getting 'stuck' too much and being pulled the wrong way, so I realized i need to raise the RPM to make it go smoother into the wood. When I raised the RPM to 21000, the wood was getting a bit darker because of burn. Is there some balance here i'm missing?
    Attached are the images.
    Thank you!
    Attached Thumbnails Attached Thumbnails IMG_20190124_213012.jpg   IMG_20190124_213039.jpg   IMG_20190124_213102.jpg
    Re: advice on chipping and milling quality with 8mm bit on 10mm plywood
    You should be cutting at 50-75mm/sec at 16,000 rpm, not 5mm/sec.
    Can you post a picture of the bit?
    What kind of machine is this?
    Aug 2017
    31
    I'm using a Stepcraft 840, with a MM-1000 spindle.
    The bit is attached in an image here.
    It doesn't make sense to me to run it at that feedrate... The machine max is 3000mm/min, so that's 50/sec, but it's not recommended (according to them) to run it at 100%.
    If I did it at 5mm/sec and 16000rpm, and it "lagged" because the wood was pushing on the bit too fast, making the axis go out of sync, that will probably have a much much worse effect if I try to up the feedrate to x10 of that... right?
    What do you think?
    That's not a downcut bit.
    Aug 2017
    31
    Ah, my mistake indeed..
    Thank you for the clarification
    Do you have any suggestions about the other issues I mentioned..?
    Apr 2004
    5737
    Try running faster but not so deep. If you only took 5 mm at a time and taking two passes to cut through, it would go smoother. Also, 4-flute bits like that are better suited to steel than wood. You only need one or two flutes for wood. With 4, it's equivalent to running at twice the RPM.
    Andrew Werby
    Website
    Aug 2017
    31
    Okay thanks. I think also compression bits would work better.
    You say 'try running faster... 5mm at a time', but this is an 8mm diameter bit, and my pass depth was 3mm... so 5mm would be deeper than what I did.
    Try a smaller bit, either 1/4" or 6mm, like this:
    https://www.amanatool.com/46202-soli...-down-cut.html
    Lower the rpm to 10,000-12,000, and try 3mm depth @ 10-15mm/sec
    Aug 2017
    31
    @ger21,
    But lowering the RPM and raising the feedrate would make the bit cut less smoothly and go faster through the wood... isn't that the opposite of what I'm trying to achieve?
    Dec 2008
    3109
    Quote Originally Posted by awerby View Post
    No.... this info is incorrect.
    the RPM is calculated to how fast the cutter is passing the material.... this is termed Cutting Speed (usually in SurfaceFeet/Minute or Metres/Minute). Once you calculate the RPM, you then multiply that by chip thickness, multiplied by the number of teeth on the cutter.
    RPM = CS / (Cutter Dia x Pi) x 1000.....metric CS m/min
    Feedrate = RPM x Feed per tooth x number of teeth
    so... a 2 flute is run 2x faster than 1 flute... but a 4 flute is programmed 2x faster than a 2 flute.
    your issue may be your feed is too slow to create a chip, it would make only dust..plus going slow also creates heat and allow burning of the wood.
    A 4 flute (steel cutting geom) doesn't have deep flutes for chip evacuation. So look for cutters made specifically for wood. You could utilize cutters designed for aluminium, as these have sharper edges, uncoated, and a greater helix angle for slicing instead of a scraping like action on the softer materials.
    Dust/chips should be removed from around the cutter to help minimise heat generation & to keep the cutter edges sharp. A vacuum system (1st choice) or a simple air blow (messier but would improve the part finish and extend tool life)
    Quote Originally Posted by yafimski View Post
    @ger21,
    If it does, decrease the depth of cut.
    Slower feedrates and higher rpm's generate heat, which dulls the tools, and makes things worse.
    Aug 2017
    31
    I'm a bit confused from all the answers.
    When I try to put my bit data into FSWizard for example, the result is to run the 8mm bit at 110 mm/sec, with 8700 RPM... MY machine can only go 50 mm/sec maximum, and i'm still confused - if I go at maximum feedrate but spin really slow, that will break my machine no?? It's like dragging a very slow spinning object really fast into something.. I can't image how 8000rpm + 50mm/sec is better than 16000rpm + 25mm/sec...
    You need to adjust the depth of cut to compensate for the weak machine.
    Try what I said above, 10,000-12,000, and maybe 15-20mm/sec, but start at 1mm depth.
    Higher rpm and slower feedrates will generate a lot of heat and destroy your bits, as you've already seen.
    Aug 2017
    31
    Thanks ger21!
    I'll try that. Compensating by reducing depth seems like a viable solution.
    I'll report back with good/bad results.
    Apr 2004
    5737
    Quote Originally Posted by Superman View Post
    [I'm a bit confused by your reply, Superman. How is what I wrote incorrect? Since according to your formula, feedrate is determined by the RPM times the number of teeth (or flutes) on a tool , and doubling those doubles the feedrate, it's the same thing as doubling the RPM, no? If I'm missing something here, please point it out in terms mere mortals can understand...]
    Andrew Werby
    Website
    Apr 2004
    5737
    [Originally you said you were running this profile cut at "full depth" which was 10mm, remember? 5mm would be half that.]
    Andrew Werby
    Website
    Dec 2008
    3109
    RPM is calculated on the diameter of the cutter to suit the material being machined.
    so... changing a cutter from 4 flute to 2 flute means that the feedrate is only to be altered ...altering the RPM changes the cutting speed that has designed for that cutter geometry.
    you may not be locked in to what is specified by the tool manufacturers, but what works for your application/setup.
    say... a 10mm dia x 2 flute verses 10mm x 4 flute.... both run at the same RPM but the 4 flute would be programmed at 2x the feed as a 2 flute
    take material steel for example
    a HSS runs about 25 m/min. so the RPM using 10mm dia is set around S800, dia 5mm would be S1600. if you double RPM, your cutter runs the risk of not lasting too long.
    That's not to say you cannot do it, you need to weigh the pros and cons.
    The principle of thinking that doubling RPM is the same as halving feed is incorrect.... the time is quicker, but you have actually doubled the recommended cutting speed that the manufacturers have designed the tools to be optimally run best
    Apr 2004
    5737
    [Most cutters can run fine in a fairly wide range of RPMs, but 2-flute cutters are designed for different materials than 4-flute ones. In general, you should run smaller tools faster than larger ones; this is based on SFM (surface feet per minute) which should be adjusted to yield an optimum chip size.]
    [I think you got that backwards. If the RPM is the same, then the 2-flute cutter would have to feed twice as fast to produce the same size chips.]
    [That would depend on factors like machine rigidity and the material being cut, but you can't expect to take as big a chip with a small-diameter cutter as with a big one; your formula has to take that into account.]
    [Not necessarily - you might have been going too slow before. As far as the formula's concerned, it's the same thing. Tool manufacturers typically specify a feedrate as a unit per tooth per revolution, as well as a SFM, which varies according to the material being cut. As long as you don't exceed these values, the tool should work fine. Here's a typical manufacturer's chart, which illustrates what I'm talking about: Niagara Cutter ]
    Andrew Werby
    Website
  1. Advice on 28" Rotary table drive design
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 01-26-2019, 07:06 PM
  2. NEWBIE ADVICE Another CNC desktop
    By djolemag in forum Benchtop Machines
    Last Post: 01-24-2019, 09:34 AM
