586,094 active members*
3,942 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > ANOTHER Bridgeport Mill conversion ( Build )
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Feb 2016
    26
    Most of the motors that where on these machines did not have mounting plates they where direct mounted
    mactec54 - Sorry, “mounting plate” was the wrong term on my part...I meant using the base plate from the stepper after disassembly.
    Joe - Saw the larger motor in your video....seems like a logical choice.
    Todd
  2. #42
    Dec 2006
    87
    Re: ANOTHER Bridgeport Mill conversion ( Build )
    well, just couldn't help myself.. i battled sleet snow and ice today... and would up with another boss mill... complete with mist unit, flood pump and tank and a good amount of taper 30 tooling...
  3. #43
    Dec 2013
    5717
    Ahhh, another project Funny how that just happens sometimes.
    Jim Dawson
    Sandy, Oregon, USA
  4. #44
    Dec 2006
    87
    So,,, one turned into four.... Finally broke down and bought a pallet jack.. used of course.. then had to repair it ..Spent the past 2 weeks making pallets for 3 of the 4 CNC bridgeports. busted my ass moving all my machines around in the shop. Even with the pallet jack its rough pushing these around by yourself ( i was using pipes ) agonized over what machines i could let go and put a bunch of wood working stuff on CL. So, now i have 3 of them where i want them and where i can work on them.. Left them on the pallets so i can easily pull them away from the wall to work on the electronics.. I may tweak them some as well.. possibly angle them a bit.. Now its time to order more parts.. need some circuit breakers, contactors etc to proceed on the controls
  5. #45
    Jul 2007
    31
    Quote Originally Posted by mongoose View Post
    Mactec, Todd, i ended up purchasing nema 42 servos with the correct mounting pattern and shaft size .. this will be a " direct fit " replacement. I just needed to get the project moving.. i previously purchased nema 34's for this machine so i will save them for the next build... at least i can use the boss to cut the adapters !!
    Joe
    What servos did you get that are direct fit? I have 2 boss 5 machines. I have the first converted with the original steppers and would like to eventually convert the other with servos.
  6. #46
    15362
    Quote Originally Posted by amishmafia00 View Post
    DMM 750W AC Servos DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Mactec54
  7. #47
    Dec 2006
    87
    DMM Tech has em...
  8. #48
    Dec 2006
    87
    Ok Gang, its been awhile... have been working on the Rigid Ram for the most part.. have the old electronics stripped out.. the machine cleaned, the oilers replaced and the control cabined blasted and powder coated.. have it re-mounted and now starting to work on the electronics
  9. #49
    Dec 2006
    87
    color matches pretty good ! lol now ill start mounting the electronics !!! Centroid Acorn stay tuned
  10. #50
    Dec 2006
    87
    here is the gear.. waiting on my VFD but i will be mounting the rest while i wait !
Page 3 of 3 123
  1. RF-31 Round Column Mill CNC Conversion Build Thread
    By tybeede in forum Benchtop Machines
    Last Post: 12-03-2014, 09:47 AM
  2. Bridgeport Boss Mach 3 Conversion Mill
    By sdmuleman in forum For Sale Only
    Last Post: 07-14-2014, 06:03 AM
  3. Replies: 9
    Last Post: 06-02-2013, 05:08 AM
  4. Bridgeport CNC Conversion
    By nikel in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2012, 03:52 AM
  5. Bridgeport Mill conversion to CNC need help
    By bwpigeon in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2009, 04:35 PM
