586,414 active members*
3,109 visitors online*
    May 2007
    16
    Tape Length???
    I have a small issue, I need to know how to convert from Bytes to Feet.
    I know this might not be a direct conversion, like bytes/x = feet.
    I assume the length in feet is from the old tape punches, and I was thinking something along the lines of x bytes per line, and 1 line = .2 inches or something. But then I could be waaaay off.
    Can someone tell me or point me to where I can convert?
    24223
    General rule is that 320m = 128kb, in actuall fact a tape row has max 8bits so and there are 8 bytes to the inch on a standard tape punch.
    You cannot really denote it in blocks or lines as these will vary with the program etc, ( 1 ASCII word is contained in one byte).
    Al.
    Albert E.
  1. Replies: 11
    Last Post: 08-15-2007, 09:06 PM
  2. cut to length
    By chathorne in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2007, 04:47 PM
  3. tape emulator
    By bbrreid in forum DNC Problems and Solutions
    Last Post: 04-12-2007, 09:03 PM
  4. Replies: 8
    Last Post: 04-09-2007, 06:58 PM
  5. Mid tape DNC
    By nervis1 in forum Fadal
    Last Post: 09-22-2004, 01:32 AM
