586,094 active members*
3,709 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Pierce delay in sheetcam
    Jul 2018
    87
    Hi all I’m trying to get my pierce delay to work in sheetcam on my home made Cnc plasma gantry and no success , I think it’s just using the 0.5seconds as default time, I’m using mach3 for Cnc plasma ,Not sure if I’m missing anything or doing anything wrong ,any suggestions?
    Attached are pics from of my current settings in spindle setup in mach3 and jet tool in sheetcam
    Bradley
    Sep 2011
    110
    Re: Pierce delay in sheetcam
    Please check if G04P command is generated by sheetcam, and check if the G04 command works on your machine.
    Jan 2015
    In shetecam you setting delay in seconds....make same setting in mach3.
  1. pierce delay doesn't work
    By da_Rayman in forum SheetCam
    Last Post: 01-04-2012, 01:34 AM
  2. pierce delay in Mach 2 ?
    By Redline in forum Waterjet General Topics
    Last Post: 11-13-2011, 01:58 PM
  3. Pierce Delay even when set to 0?
    By Wolfesmetalfab in forum Mach Plasma / Laser
    Last Post: 02-03-2009, 05:00 AM
  4. Pierce delay and plunge rate settings.
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 07-20-2008, 12:05 AM
  5. Pierce Delay And Plunge Rate
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 01-30-2007, 03:48 AM
