586,655 active members*
2,413 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Yaskawa G3 Makes Clicking Noise and Won't Start
    rallyx99 Guest
    Hey Everybody,
    I'm having some trouble with my Yaskawa G3 (CIMR-G3U27P5) spindle drive. I'll fire up my machine (a 1996 Tree Journeyman 425 with Dynapath Delta 50 control) and the spindle drive will make a clicking noise like there's a contactor or something down in the bottom of the drive that's trying to latch but can't quite close. Sometimes drive will start to power up, other times I get nothing whatsoever. Anybody have experience with anything like this? Barring some amazing solution, I'm thinking about pulling the drive out and sending off to get repaired. I'm in Dallas, TX and was wondering if any of you could recommend somebody to do the repairs?
    Another thing I've been considering was pulling the drive (Yaskawa CIMR-VU2A0040FAA) out of another machine and swapping it over. One of the problems is that wiring to this drive is different (its on a Tree Millenium 4200 with an Anilam 1400 control) and I can't quite figure it out.
    Anyway, please see attached videos to get a better idea of what's going on.
    https://youtu.be/Alh293-YF1k
    https://youtu.be/8aan-2ww8Aw
    15362
    Re: Yaskawa G3 Makes Clicking Noise and Won't Start
    Quote Originally Posted by rallyx99 View Post
    Hey Everybody,
    What are you powering the 3Ph power with, or are you using single phase supply
    Mactec54
    15362
    Hey Everybody,
    The VFD Drive fault CPFD1 is a commination problem the F250 is a fault also but don't have that in the manual, which could be a Ground fault or an open phase
    Mactec54
    rallyx99 Guest
    I have the machine hooked up to a standard 208Y power supply. L-L voltage runs 213v in my shop which should be well within the safety margin. I’ll check the main AC terminal blocks again, but the wires connecting the drive to the power supply should be good to go.
    rallyx99 Guest
    Thank you, I’ll try to find out what that “F250” means. This is frustrating!
  1. Z-Axis Motor Makes Clunking Noise
    By CH33 in forum Gecko Drives
    Last Post: 12-14-2017, 01:05 PM
  2. spindle makes noise.
    By ehudkdr in forum Spindles / VFD
    Last Post: 11-06-2017, 03:29 PM
  3. Replies: 15
    Last Post: 02-26-2015, 02:07 AM
  4. Coupling makes noise
    By kostas1 in forum Linear and Rotary Motion
    Last Post: 11-16-2013, 09:32 PM
  5. New K2 2514 Router makes noise
    By grossmanator in forum K2CNC
    Last Post: 11-17-2010, 07:35 PM
