586,717 active members*
3,225 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > DG4S-16035 Tuning on DynaMyte 3000 lathe spindle
    Jul 2013
    I bought a DM3000 a few years ago, and thanks to some great threads on this forum converted the axes to Mach3 pretty easily. I bought a DG4S-16035 back in 2017 and finally got around to installing it for the spindle control. I can't seem to get the drive configured for my servo motor, and am starting to think it is an encoder issue. The system specs are:
    Uxcell BoB
    UC100 USB to serial controller
    DG4S-16035 servo driver
    SEM 30U4-48 servo spindle motor
    1000PPR encoder https://www.amazon.com/gp/product/B01EWK93BA
    Encoder is on a pulley just under 50% of the size of the spindle pulley so it is being spun around 2200PPR
    In the CNCDrive servoconfig software I'm getting a sine wave with ripple, the servo is oscillating back and forth and has tiny mini jerks unless I increase the test steps to around 2,000 and the sampling time up to 100. I have read lots of message boards, watched numerous youtube videos, and tried everything in the CNC4PC tuning guide. While I've tried a wide range of settings in the servo config software, I can't seem to change the oscillating behavior. I'm wondering if I need a lower resolution encoder, could their be a wiring issue, or is this a tuning issue I just cannot seem to tune out? Any ideas are appreciated.
    Josh
    Jul 2013
    Re: DG4S-16035 Tuning on DynaMyte 3000 lathe spindle
    Based on discussion with Arturo at CNC4PC I got it closer, but still have an oscillation. This is the best I've gotten it, if I bump up the amperage it no longer spins but instead only oscillates.
  1. DynaMyte 3000 cnc
    By mechdraw63 in forum Dyna Mechtronics
    Last Post: 02-12-2016, 10:31 PM
  2. DG4S ---- 16035 vs 8020
    By Bob La Londe in forum CNC4PC
    Last Post: 11-03-2015, 06:16 PM
  3. Dynamyte DM-3000 lathe schematic
    By Jeff-Birt in forum Mini Lathe
    Last Post: 08-28-2014, 01:53 PM
  4. Wanted: DynaMyte 3000 Lathe Post Processor
    By george klammer in forum Dyna Mechtronics
    Last Post: 10-03-2011, 11:13 PM
  5. DynaMyte 3000 cnc lathe
    By Cliff. Johnston in forum Mini Lathe
    Last Post: 07-26-2008, 02:51 AM
