586,556 active members*
3,530 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help in setting up 2.2kw 220v 400Hz spindle with L&T Cx2000 VFD
    May 2016
    6
    I have a Chinese 2.2kw water cooled 400Hz 220V 10A spindle and VFD manufactured by Larsen And Turbo Model LTVF-C10011BAA, can someone help me here in setting the vfd? The spindle will be used for my cnc router
    Attached Files Attached Files
    15362
    Re: Need help in setting up 2.2kw 220v 400Hz spindle with L&T Cx2000 VFD
    Quote Originally Posted by kamwa View Post
    Now that is a different VFD Drive, the basic settings are not to hard to do, if you can understand how to set each Parameter from the KeyPad, as long as you get all the main Parameters set for your spindle, you should not have any problems there may be other Parameters to set once you get it going
    0.00 1100=400
    Accel 1101=8 ( Accel Adjustable )
    Decel 1102=8 ( Decel Adjustable )
    F21 1215=400
    F22 1216=400
    F23 1217=10
    F25 1219=400
    F26 121A=100
    F51 1233=120
    F54 1236=120
    F57 1239=120
    F58 123A=20
    F67 1243= ?? ( Your Voltage supply 220v/230/240 Can Stay at Default 220 if Unsure )
    H23 1317=100
    H30 131E=2.2 ( Kw )
    H31 131F=2 ( Poles )
    H33 1321=10 ( Amps )
    H41 1329=1 ( After you have set all Other Parameters You Can Do Auto Tune=1 )
    H47 132F=120
    Mactec54
    May 2016
    6
    Thank you so much Max, I'll update the parameters on this weekend and I'll let you know
    By the way I did set the following parameter last Saturday but when i set frequency 120hz and press Run the spindle start to rotate(forward) but when it reached a frequency of around 12Hz the drive trip and display an alarm I0L (inverter overload)
    My parameter are
    ACC=12
    DCC=12
    drv=0
    Frq=0
    F21=400
    F22=400
    F25=400
    F26=120
    The rest are set to default
    My spindle winding resistance are as follows
    1-2=1.6 Ohm
    1-3=1.6 Ohm
    2-3=1.6 Ohm
    4 shorted to spindle body
    4 and the other terminals are open circuited.
    I think the drive trip because of my settings. Anyway I'll use your suggested parameters on this weekend
    NB:Sorry for my bad English
    15362
    My parameter are
    ACC=12
    DCC=12
    drv=0
    Frq=0
    F21=400
    F22=400
    F25=400
    F26=120
    1-2=1.6 Ohm
    1-3=1.6 Ohm
    2-3=1.6 Ohm
    You have to fix Pin 4 Ground in the Spindle most are not connected and need to be, this did not cause your problem though just something that needs to be corrected
    There could be other Parameters to set but do what I posted first and 120Hz is ok for your minimum speed I have that at 100Hz in what I posted
    Mactec54
  1. Replies: 3
    Last Post: 05-26-2017, 08:27 PM
  2. 1.5 KW 400hz spindle
    By skybox in forum Spindles / VFD
    Last Post: 03-14-2017, 01:57 AM
  3. Replies: 3
    Last Post: 04-16-2014, 01:22 PM
  4. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
