586,103 active members*
3,859 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Help me please! Plasma cutting with -1.5 mm of error
Results 1 to 1 of 1
    Jan 2019
    Question Help me please! Plasma cutting with -1.5 mm of error
    Hi guys
    I have got a table smart 2 Steel Tailor with SF-AH200 controller, running a hypertherm 105. The problem with the machine is that the external cuts are always 1.5 mm to 1.7 mm smaller than the programmed one, if I program a square of 100 mm x 100 mm the result is 98.5 mm x 98.5, I have already verified the parameter "Numerator" and it's fine because the interior cuts are good and distances between centers.
    What should I adjust in the control to solve this? Do you have any idea?
    Thank you
    Attached Thumbnails Attached Thumbnails WhatsApp Image 2019-01-29 at 11.39.39 AM.jpg   WhatsApp Image 2019-01-29 at 11.39.40 AM (1).jpg   WhatsApp Image 2019-01-29 at 11.39.40 AM (2).jpg   WhatsApp Image 2019-01-29 at 11.39.40 AM.jpg
