586,051 active members*
3,851 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > POST ISSUE EDGECAM 2011 fanuc milling post
Page 1 of 2 12
Results 1 to 20 of 25
    Nov 2005
    41
    need to modify post so % character is at very top of program.
    right now the problem is turret and tool description are posting above % character.
    help please
    Eric
    Dec 2008
    441
    Re: POST ISSUE EDGECAM 2011 fanuc milling post
    Hi!
    Do you have the CGD files for the postprocessor?
    Im not an expert here, but it should be easy.
    -Robert
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Nov 2005
    41
    was attached
    Dec 2008
    441
    Ok, thanks, is this a file\postprocessor you have payd much money for? then you should not upload it, i was asking only about that you have the file, so you can change it
    I don`t have time right now, but i will take a look at it in a few hours
    Nov 2005
    41
    Thanks, I am not an edgecam user just trying to help fellow programmer out with this.
    He does no have much experience with post edits.
    So any help is greatly appreciated.
    Should I remove the previously attached file?
    Dec 2008
    441
    So you only need a % symbol at the start, and NOT on the end? or do you need in both places?
    Nov 2005
    41
    both
    Dec 2008
    441
    If the guy pay for example $2000 so... YES!
    If he get it for free, i think you can leave it here
    Do you wan`t it back with the adjustment? or do yoiu want to try to fix it if i told you what you should do?
    Dec 2008
    441
    Send me an PM with your email adress, and i send it back with the % symbol in start and end
    Nov 2005
    41
    whatever you think would be least effort for you - remember is old version
    Dec 2008
    441
    Im done with it. So just send me you email adress
    Nov 2005
    41
    sent pm
    Dec 2008
    441
    PP sendt
    Nov 2005
    41
    ok now problem we have is % character in front of each turret and tool description in the header, (is multi tool program). We need only one occurrence at very top and one at very end of program.
    Dec 2008
    441
    Ok, give me some minutes
    Dec 2008
    441
    Hmm... I can`t place it before the tool information, only after the tool list..
    But give me some minutes/days i will figure it out
    Dec 2008
    441
    New PP sent!
    Nov 2005
    41
    now programs are missing % character at top
    Dec 2008
    441
    Hmmm.. Wierd, that work for me..
    -Check it-
    Dec 2008
    441
    Here is the .nc code i get out.
    Please check that you are using the latest PP
    (* Turret Position : 1 Tool Description : 25.0 mm Multi-Flute End Mill)
    (* Turret Position : 2 Tool Description : 8.0 mm Multi-Flute End Mill-LS)
    ( Innovative Engineered Solutions Inc.)
    (* Machine Tool : Chevalier Mill)
    (* Part Name : Parasolfot Chavalier test)
    (* Sequence : Operation 1)
    (* Programmed By : )
    (* Date : 01/30/19)
    (* Time : 22:31:49)
    (* Total Machining Time : 6.407 Minutes)
    O0001 (Parasolfot Chavalier test)
    G17 G40 G80 G90 G94
    G00 Z3.0
    X0.0 Y0.0
    T01 M06 (25.0 MM DIA MULTI-FLUTE END MILL)
    M3 S9999
    G00 G55 X0.0 Y0.0
    G43 Z3.0 H01
    G00 X0.0 Y0.0
    Z1.9685
    M8
    X0.1969 Y-1.8102
    Z0.1969
    Z0.1181
    G01 Z-1.2598 F7.87
    Y-1.7315
    G17 G03 X0.0 Y-1.5347 R0.1969
    G02 I0.0 J1.5347
    G03 X-0.1968 Y-1.7315 R0.1969
    G01 Y-1.8102
    G00 Z0.1969
    Z1.9685
    X0.0 Y0.0
    Z3.0
    X0.0 Y0.0
    M9
    M05
    T02 M06 (8.0 MM DIA MULTI-FLUTE END MILL - LS)
    M3 S9999
    G00 G55 X0.0 Y0.0
    G43 Z3.0 H02
    G00 X0.0 Y0.0
    Z1.9685
    M8
    X0.1969 Y-1.4756
    Z0.1969
    Z0.1181
    G01 Z-1.2598 F7.87
    Y-1.3969
    G03 X0.0 Y-1.2 R0.1969
    G02 I0.0 J1.2
    G03 X-0.1969 Y-1.3969 R0.1969
    G01 Y-1.4756
    G00 Z0.1969
    Z1.9685
    X0.0 Y0.0
    Z3.0
    X0.0 Y0.0
    M9
    M5
    G00 Z3.0
    X0.0 Y0.0
    M30
Page 1 of 2 12
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Fanuc Qi MD Edgecam Post Processor
    By zekry in forum EdgeCam
    Last Post: 04-22-2016, 02:41 AM
  3. Fanuc 6T Edgecam Post Processor
    By Zoni in forum G-Code Programing
    Last Post: 05-03-2010, 06:02 PM
  4. Fanuc 6T Edgecam Post Processor
    By Zoni in forum Fanuc
    Last Post: 05-03-2010, 05:56 PM
