586,075 active members*
4,137 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese Spindle making rattling noise !
Page 1 of 3 123
Results 1 to 20 of 49
    Jan 2019
    24
    Exclamation Chinese Spindle making rattling noise !
    Hello everyone.
    I purchased a Chinese spindle via AliExpress. It is a 1.5 kW, 24000 rpm, ER16 liquid-cooled spindle.
    When I run the spindle above 11,000 rpm it makes some kind of rattling noise like something is interfering inside, but the shaft spins smoothly and below 11,000 rpm the noise disappears. There is no resistance felt when I spin the shaft with my hand. It is perfectly smooth. I contacted the seller and he said it is normal and that I continue to use it. But the noise is quite worrying me.
    https://www.youtube.com/watch?v=LrzEDfsBpPY
    Since I was just testing the spindle for a few seconds I did not connect the water cooling tubes yet (in the video). Later I did a long run (running continuously for about an hour) with the tubes connected and water flowing through it, the spindle seemed to be working fine, no overheating or reduction in speed except for the noise it keeps making.
    Can anyone tell me what is the problem? Is it all right to continue using it? Or what can be done to stop the noise?
    Thank you !
    Nov 2012
    1267
    Re: Chinese Spindle making rattling noise !
    Notice how the frequency of the noise stays the same as the spindle spins up and down? Just a wild guess, but I suspect it's VFD output that has little "glitches" in it.
    Try this: change the VFD stopping mode from "Decelerate to stop" to "Coast to stop". See if the noise goes away as soon as you hit the Stop button.
    Jan 2019
    24
    Thank you for your reply!
    Will check and let you know.
    Jan 2019
    24
    CitizenOfDreams you are right! There is some kind of glitch from the VFD output. I changed the settings as said by you and the noise disappeared as soon as I pressed the stop button. Can you further help me in correcting the issue? Any changes in VFD settings ? I am using a cheap chinese VFD. Model : YL620-A 2.2kW output and the spindle is a 1.5kW 400Hz model.
    Thank you!
    Nov 2012
    1267
    Quote Originally Posted by suganesh95 View Post
    I would try changing the carrier frequency and see what happens.
    Jan 2019
    24
    Honestly, I'm a newbie and there are many settings in VFD that I am not able to figure out what they mean. I am uploading pics of my present settings and maybe you can help me out with it.
    (P.S - Ignore the stopping mode as I have set it to "coast to stop")
    Thank you.
    Nov 2012
    1267
    Is this a complete list of functions? Looks like there should be much more. The "Carrier frequency" parameter is usually way down the list.
    Jan 2019
    24
    There are still many ! I just uploaded the ones which i set. Anyways i will upload the remaining ones so that you can have a look.
    Please go through them.
    Thank you !
    Attached Files Attached Files
    Nov 2012
    1267
    Carrier frequency, or PWM frequency, is parameter P12.19. Try cutting it in half or doubling it and see what happens.
    15362
    Hello everyone.
    Thank you !
    Have you checked the Ground is connected, pin 4 in the spindle, this has to have continuity to the spindle body, if not this has to be corrected, it also sounds like you have some parameters set incorrect, do you have a list of the parameters you set
    Just looked at what you posted no they are not set correct I will post you a list of what you have to set, but first we have to know which VFD Drive you have
    Mactec54
    15362
    Quote Originally Posted by CitizenOfDreams View Post
    You are miss leading this new user if he has not changed the carrier frequency then the default setting is fine for these spindles, his main Parameters are not set correct this is something you can't make guesses with
    Mactec54
    15362
    Thank you !
    Things I need to know to be able to give you the correct parameters to set, don't run your spindle again until you have the correct Parameters set
    VFD Drive spec's make and model #
    Spindle voltage ??
    Spindle Amps ??
    A Photo of the VFD Drive also would help to see if it is real or a clone
    Mactec54
    15362
    Thank you !
    Ok by what you posted Correct these 2 Parameters and then try, P00.00=400 if this is set incorrect will smoke your burn your spindle, so hope there is no damage been caused
    P00.00=400
    P00.09=100 this is your minimum speed these or your spindle can run, I will check
    Do you have the PDF of the manual
    Mactec54
    Jan 2019
    24
    Really sorry for the delay in reply as I was having my exams so was busy preparing for it.
    CitizenOfDreams
    Actually, I did a factory reset and the default parameter for P12.19 was set to 6kHz in the VFD and not 8kHZ as mentioned in the manual. So what I did was I set it to 8 to check what happens. and the noise reduced drastically. Only a feeble amout was audible when went closer to the spindle to hear it. Later i set it to 10kHZ and the noise disappeared !
    So do you recommend 10kHZ for my spindle?
    Jan 2019
    24
    mactec54
    Yes, pin 4 is connected to the ground.
    VFD is a Chinese YL620-A, 2.2kW, single phase input to three phase output, 400Hz, 10A, 220V
    The spindle is a Chinese 1.5kW, 24000 rpm, 400Hz, Liquid cooled spindle, 8A, 220V
    For the parameters please check my post above I have uploaded a pdf file.
    Aslo P 00.00 is the AC mains frequency i.e the frequency present in the wall socket plug and not the spindle frequency and here in India, it is 50Hz P 00.04 is the max. Spindle frequency.
    suganesh95 Guest
    mactec54
    Please check this link: https://reps.cc/?p=113
    Here the person uses the same VFD as mine and has given the basic parameter settings. Seems ok to me, but do give your suggestions.
    Thank you !
    15362
    mactec54
    Thank you !
    Yes the very first Parameter is incorrect that needs to be 400Hz it has nothing to do with your supply frequency you have to use the Spindle Motor Frequency
    No with your carrier Frequency it can go as high as 10 but unless you have a way to check the internal temperature it would not be a good Idea to go above 8, so say at 8 is what I recommend for these spindles 6 to 8 is a good setting, at 10 the winding start to heat up so you don't want that to be happening if it want long life from your spindle
    These are what you need to set
    P00.00=400
    P00.09=100
    P00.10=25
    Mactec54
    suganesh95 Guest
    mactec54
    Ok, will look into it! Can you also tell me what does it mean? and do you recommend any changes in the other parameters?
    Thank you !
    15362
    mactec54
    Thank you !
    What I just posted you have to change or you can damage your spindle if you don't, there could be other parameters to change, but without a complete PDF of the manual I can't give you any other parameters, I have a different model VFD manual from this manufacture form what you posted, but it is different, I need a complete manual from the manufacture for your VFD model if you have one
    Mactec54
    suganesh95 Guest
    mactec54
    I have changed the first parameter to 400Hz as said by you.
    I am again attaching the pdf and those are the complete set of parameters that the VFD supports. rest all are just connection diagrams and maintenance instructions.
    Also what about the PWM frequency settings? i.e parameter P12.19 ? is 10kHZ fine ?
Page 1 of 3 123
  1. HDS Spindle making noise after shaft kit replacement
    By branchy in forum Commercial CNC Wood Routers
    Last Post: 10-14-2019, 02:54 PM
  2. Help with PRT-E1500 VFD 220v Please, spindle making a noise but not turning
    By graeme1234 in forum CNC Machine Related Electronics
    Last Post: 04-20-2019, 11:26 PM
  3. Chinese spindle 2.2 kW funny noise
    By FeliceM in forum Spindles / VFD
    Last Post: 06-26-2017, 01:15 AM
  4. Spindle making grinding/humming noise
    By machinisto in forum Haas Mills
    Last Post: 10-21-2014, 09:05 PM
