Re: okuma turn-cut option
hy duivenhok so far i did not used this function, but you may find some infos about it :
... look through the manuals that have been delivered with the machine, and search inside them " tun cut ", "turn-cut", etc; it may be inside the programing manual, or maybe inside the special-functions ? those manuals are located somewhere inside the controller; if you find infos inside them, it means that the machine is capable of this function
... inside igf, search for the turn-cut operation; if you find it there, it should mean that the function is installed, since igf reflects actual specs package
... newer machines, at least some hmc, have a specialized application ( interface ) for this function; i don't know if it comes as default, or you must download it ? i guess the okuma rep should now more about it
kindly
