When loading an existing relief to New Model, my project relief information gets switched around. On the original model the Max. Z is 1" and the Min. Z is 0". The new model relief information reads the opposite way.
Even the Shape Editor image reversed. The original 3d image has the vector areas raised above the base panel, but on the New Model the 3d image has the vector areas recessed into the base panel.
I tried inverting the Z parameters on the new model, but the wrong areas were getting hogged out. What did I inadvertently change to cause the problem?
