586,075 active members*
4,087 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Used LS6840 PRO Laser Cutter Co2 with 60W tube and Bofa AD Oracle Fume Extractor
Results 1 to 1 of 1
    Feb 2019
    Hi
    I have a Used LS6840 PRO Laser Cutter Co2 with 60W tube and Bofa AD Oracle Fume Extractor
    + PC
    Price £4000 (cost me £6750)
    Used one year - total around 300h on 16% power.
    LS6840 PRO
    Class 1 laser system
    60W tube
    Machine can fit through a standard single doorway without needing to be disassembled
    Dual red dot pointer system for easily and quickly lining up your work
    Motorised bed height adjustment and slatted non-reflective aluminium bar bed for supporting a wide range of materials and weights
    High quality optics provide high accuracy, reliability and long life
    Hinged pass-through panels front and rear allow larger items to be cut and engraved
    Air assist to control heat and disperse smoke and debris around cutting nozzle
    Water flow switch to provide protection against failure of cooling system
    Louvred cabinet ventilation slots ensure maximum enclosure safety
    Safety switch prevents operation of machine with lid open
    CUT AND ENGRAVE:
    Paper, card and print media
    Fabric
    Leather
    Acrylic, nylon and other non-PVC plastics
    Plastic laminates
    Latex and rubber
    Plywood and MDF
    Wood and wood veneers
    ENGRAVE ONLY:
    Glass, granite, slate and marble
    Anodised and coated metals
    Uncoated metals
    Full Details - http://hpclaser.co.uk/index.php?main...products_id=38
    Inc Vat - location UK Derbyshire
    Matthew
