586,094 active members*
4,142 visitors online*
Page 16 of 43 6141516171826
Results 301 to 320 of 848
  1. #301
    Oct 2009
    733
    Re: David A's New 2x3 Bench Top CNC
    Quote Originally Posted by Arjay View Post
    Not to hijack your awesome thread, but speaking of rotating ball nuts, here is my design:
    Arjay, thank you, you are not hijacking,
    it is related to what I am doing here.
    I am not a machinist so I had expert people of the
    trade built four different prototype designs until I
    came to the one I am using now. It all comes down
    to build-ability at a shop at a reasonable cost.
    And I want to keep everything manufactured in the US as much as I can.
  2. #302
    Oct 2009
    733
    Carefully push the ball nut assembly
    with the angular thrust bearings into
    the bearing seat on the X-plate,
    positioning the belt over the pulley:
    Attachment 415068
    Make sure the shoulder bolt is aligned
    with the ball nut retainer notch:
    Attachment 415070
    You are welcome to utilize any parts of the design for your personal use.
    Please contact me for commercial applications.
  3. #303
    Oct 2009
    733
    Install the bolts for the retainer
    and install the dust cap:
    Attachment 415072
    Bottom view:
    Attachment 415074
    Z-axis drive on the machine:
    Attachment 415076
Name:	29 IMG_7404.jpg
  4. #304
    Oct 2009
    733
    Install the top brace of the
    Z-slide to the 30mm shafts:
    Attachment 415080
    Push the Z-slide up to
    the top of the ball screw:
    Attachment 415082
    And tighten down the
    Z-slide to the ball screw:
Name:	32 IMG_7709.jpg
  5. #305
    Oct 2009
    733
    Z-slide finished:
    Attachment 415086
Name:	34 IMG_7717.jpg
  6. #306
    Oct 2009
    733
    The rotating ball nut drive can accommodate
    from 20 to 40 tooth pulleys on the stepper side.
    The ball nut side is fixed at 40 tooth.
    That gives a belt drive gearing of 1:2 to 1:1 ratio.
    With a 20 tooth pulley, 2,000 rpm on the servo would equate to 157.48 ipm
    With a 40 tooth pulley, 2,000 rpm on the servo would equate to 314.96 ipm
    I will be using a 30 tooth pulley on the Z-axis for testing.
  7. #307
    Oct 2009
    733
    X-AXIS BALL SCREW INSTALLATION:
    Assembled X-axis plate installs on the back,
    driving directly the lower carriage plate:
    Attachment 415104
    Lower mounting points:
    Attachment 415106
Name:	38 IMG_7547.jpg
  8. #308
    Oct 2009
    733
    Install ball screw ends into
    pockets on A/Y carriages:
    Attachment 415110
    Attachment 415112
Name:	41 IMG_7537.jpg
Name:	42 IMG_7563.jpg
  9. #309
    Oct 2009
    733
    X-Axis ball screw finished:
Name:	43 IMG_7542.jpg
  10. #310
    Aug 2018
    621
    Looking good, looks like you should be testing the motion this week.
  11. #311
    Oct 2009
    733
    Thanks Dan, I might be able to do that.
    Y AND A - AXES BALL SCREW INSTALLATION:
    Assembled Y/A plates mount directly to the 3060:
    Attachment 415124
    Bottom part:
    Attachment 415126
    With the sensor installed:
    Attachment 415128
    Wires tidied up:
    Attachment 415130
    And ball screw ends fixed in end plates:
Name:	48 IMG_7524.jpg
  12. #312
    Oct 2009
    733
    This is where I am right now with the build.
    I will post from now on as I proceed in real time.
    Thank you all for your inputs.
  13. #313
    Aug 2018
    621
    Nice looking forward to seeing it finished up and seeing the hold down and coolant system in action. Very creative design on the coolant/vacuum table.
    Dan
  14. #314
    Oct 2009
    733
    Question:
    Is it better to have the VFD being on all the time or switched on/off by the relay?
  15. #315
    Aug 2018
    621
    On mine the drive is powered up when the controller is powered up but the signal to the Acorn board goes through the relay board. Eventually as I was telling you earlier I'm going to install contactor for the VFD so I can turn it off from the controller or a plc if I need to. Right now I have to turn off the breaker that the VFD goes to if I want to turn it off. It works fine this way, but I would rather do it from the CNCPC instead of opening the enclosure.
    Dan
  16. #316
    Oct 2009
    733
    From what I read, some people leave the VFD on 24/7. I wouldn't know if it is any better or not.
  17. #317
    15362
    Quote Originally Posted by davida1234 View Post
    Question:
    When you shut the machine down the VFD should turn off
    Mactec54
  18. #318
    Aug 2018
    621
    I definitely wouldn't leave it on 24/7 since the fan runs on my VFD the whole time it's on. I'm pretty sure yours will too since I think we both have the same model VFD. That's one of the reasons I want to be able to turn it on and off from the controller since the fan is loud and my machine sits idle for long periods of time.
  19. #319
    Oct 2009
    733
    Ok, thanks, will do.
  20. #320
    Apr 2016
    841
    Quote Originally Posted by Ntl View Post
    Dan
    FWIW, I've heard many times that you shouldn't use contactors in your boxes, because they put out a lot of noise. Personally, I don't know either way. I don't have test equipment to measure for it. Nevertheless, I decided it was better to be safe than sorry, so I removed the contactors and replaced them with 40 amp rotary switches. No downside, except for a few dollars. 40 amp was way larger than I needed, but the price was right.
    Gary
  1. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  2. CNC bench lathe or other small bench lathes
    By Scootworks in forum Turning Machines
    Last Post: 08-20-2011, 06:36 AM
  3. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  4. David
    By [email protected] in forum Fanuc
    Last Post: 12-11-2009, 08:56 PM
