The brygga 2x3 desk top router breaking in.
400 ipm X and Y, 300 ipm Z, 20 acceleration:
https://youtu.be/k4YDFBgFRg4
Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
im still thinking to use hdpe or acrylic for my spoilboard
I don't have much experience with acrylic but would
think that it wouldn't be too suited for spoil board usage.
It's stiff and brittle, would probably crack when you drive
a screw into it and would melt with a duller bit when you
cut through a material you have on it.
I do have quite a bit of experience with HDPE and think that it
is pretty close to being the perfect material for a spoil board.
It rarely melts on even a dull bit as it is fairly easy to cut (68D),
holds screws very well, is extremely resilient (try to rip a milk jug),
holds its shape even over time (negligible cold creep), doesn't
swell or shrink with moisture, is impervious to just about any
chemical including oils, coolant and water and doesn't create
any fuzzies or dust as a wooden spoil board will.
I think the reason that it is not used more often is because
most metal guys don't know much about it and the fact that
it costs about 6-7 times more than a sheet of MDF.
Quick question:
UCCNC seems to run Mach 2/3 Arc.txt files just fine.
Is that the post processor mode to use or are there more optimized post processors for UCCNC?
Thank you
Thank you Mactec and Ger,
Yes, it runs fine with the Mac2/3 code.
Brygga desktop is getting close to test cuts.
First, the machine has been modified so that
the ball screws are fixed only at one end and
the other end is floating.
For Y/A, one clamp side has been modified
to have a rubber bushing for the floating end:
Attachment 419282
For X axis, one of the Y/A carriages had to be
taken out. For that, I used a car jack to unload
the weight of the gantry:
Attachment 419284
Carriage slid out easily:
Attachment 419286
A seat for the rubber bushing was machined into the carriage:
Attachment 419290
I don't know of any additional improvements but
with one ball screw end floating, the machine
seems to run a bit smoother and quieter.
All these modifications have been incorporated
into the master file for future cuts.
BB ply spoil board installed:
Attachment 419298
Big front braces installed:
There will be two clear screens on the machine.
They are not mandatory for function but improve
the dust collection and coolant retention.
Attachment 419302
They simply slide in and out with the grooves of
the plastic trim around the machine:
Attachment 419304
Attachment 419306
The back screen can be left in place as you will
never get there. The front one will be taken out
for loading/unloading or just not be used if no need.
The back screen placed in:
= = = = WANTED = = = =
I will run test cuts for wood, plastics and aluminum.
However, so far, I've cut mainly plastics and aluminum.
I have Aspire but never did any 2.5D or 3D carving and
have no knowledge whatsoever about it.
If there is somebody with a 3D carving file and wants
to see how the machine performs with 3D carving, I will
gladly try to run it as I am curious myself. The file should
have all tool paths and tool types listed so I can get
those bits and set up the machine accordingly.
Thank you.
Hi Mactec,
I setup the VFD as called out above. Everything
seems to work fine but I have two questions:
PD174=??? Where do I find the max. Amps? It is not on the VFD.
When I run the spindle, it goes directly to 400 (24,000 rpm).
The up/down arrows run it down very slowly.
Is it possible to start the spindle with a lower speed like 16k or 18k
and adjust up/down from there?
Thank you for the input, wmgeorge.
Unfortunately, I have a HuanYang VFD, not a Hitachi and
the documentation on that is quite vague and I don't know
much about VFD setups to start with. So I thought, I ask.
Does yours start up at full speed? I prefer that the spindle
starts at around 16-18k and I can go up or down from there.
I also would like to know if there is a way to adjust the speed
faster than scrolling from the 1/100th digit. Maybe a pot might
be a better way to do it.
Might be in the manual. I think it's either 10 or 11.PD174=??? Where do I find the max. Amps? It is not on the VFD.
You should be able to set the frequency before you start it. I don't recall if it remembers the previous setting or not?
There's a plugin for UCCNC that works well, if you want to control it from the software.
