586,103 active members*
3,748 visitors online*
Page 33 of 43 233132333435
Results 641 to 660 of 848
  1. #641
    Oct 2009
    733
    Re: David A's New 2x3 Bench Top CNC
    Since the signal at the breakout board is not changing, it's either:
    1) The Motor doesn't actually fault.
    Well, the motor is stopped by the bumper. The green light on the servo is yellow, blinking. The servo will not responding to jog commands.
    2) The HLFB is not working, or the software is set incorrectly.
    There is really not much to set with the software. Pin, port and function. Or am I not correct?
    3) There's a short in your circuit boards.
    If everything else work with the circuit boards, nothing pops or smells and all other inputs work, I would say probably not.
    Using In Range to check following error should guarantee that you get a signal, as I'm not sure what will actually trigger the "Servo On" signal.
    I will try that if Teknic doesn't find anything. They asked several times if my servos were on "Servo On".
  2. #642
    Oct 2009
    733
    Quote Originally Posted by Ntl View Post
    Correct he's not but in the end it will be interesting if a plc or relay board is whats needed for it to work properly.
    My thinking is that if the HLFB circuit is able to trigger a relay, it should be able to trigger an input.
    Relay to me sounds like a bandaid. On Acorn site, they used them for other purposes like homing, I believe.
  3. #643
    Aug 2018
    621
    Quote Originally Posted by davida1234 View Post
    David have you hit up cnc4pc yet? They might be able to give you some info.
  4. #644
    Aug 2018
    621
    No they use them to handle the alarm signal as well, you had me curious so I read a bunch of post's about. BTW they aren't wired in series to the relay, so I don't think they would trigger a single relay if wired in series. Gary C even did a video talking about why he uses a relay board and what it does.
    I've been kicking around building a new machine and using servo's so I'm very interested in the issue. I was also looking at DMM AC servo's but it seems guys have had issues with them as well.
  5. #645
    Oct 2009
    733
    No, I have not yet but that gave me another idea.
    Why not try another input on the BoB?
    Maybe the one I know is definitely working......the homing input.
  6. #646
    Aug 2018
    621
    Try it out, I would still try wiring just one hlfb up and see if you get a signal. If you do, then wire two and keep going until you don't get a signal anymore. It would be a way to see if it is a resistance issue with the clearpaths.
  7. #647
    The easiest way to check the circuit is to disconnect the two wires from the breakout board, and wire them to a power supply, with a place to check if the voltage drops out. It should act like a switch.
  8. #648
    Aug 2018
    621
    I'm also wondering if it is a resistance issue, could it be from the gauge wire that's being used or the connections? I'm by no means a electrical expert just tossing some ideas out there.
  9. #649
    Oct 2009
    733
    Interesting. Disconnect which two wires and wire which to a power supply?
    Could you elaborate some more, please?
  10. #650
    Oct 2009
    733
    RJ45 connectors use 24 or 26 ga wire. HLFB, from what I understand, is 1 mA.
  11. #651
    Oct 2009
    733
    Dust Collection Installation:
    While I wait for Teknic to come up with some suggestions, I am
    going to connect the DC system on the machine to the Dust Collector.
    Main pieces:
    Two truss head bolts, two eye nuts, one collar and washers and nuts:
    Attachment 419744
    And one 3/8 structural fiber glass rod, 5 ft long:
    Attachment 419746
  12. #652
    Oct 2009
    733
    Install bolts on the rear leg of the frame:
    Attachment 419748
    One up high, one at the bottom:
    Attachment 419750
    Install the eye nuts:
    Attachment 419752
    Slide the FG rod through the eye nuts,
    Tighten the collar on the FG rod with
    about one inch of rod at the bottom:
    Attachment 419754
    Fiber glass pole installed:
Name:	32 IMG_8014.jpg
  13. #653
    Sep 2005
    1740
    Well if they are just solid state NPN or PNP transistors I doubt if they would be wired in series. If they are in parallel and either went high sourcing a voltage or low sinking a 5 vdc signal (resistor in series) that would work. I looks as if not many users are taking advantage of that safety circuit.
  14. #654
    Oct 2009
    733
    Quote Originally Posted by wmgeorge View Post
    wmgeorge, please see the comment from Teknic below. And yes, they are wired in series:
    "3rd party controller setup:
    We have had countless customers that have successfully used 3rd party PLC's and CNC controllers with the HLFB servo on function."
  15. #655
    Oct 2009
    733
    Screw on a 3'-6" long 4" DC hose on the collector on the machine:
Name:	33 IMG_8003.jpg
    On a 4" elbow, clamp another 4" DC hose long enough to reach the DC vacuum:
    Attachment 419764
    Attachment 419766
    Drill a 3/8 hole on the inside of the elbow:
Name:	36 IMG_8006.jpg
  16. #656
    Aug 2018
    621
    I was just reading the clearpath manual and 1mA is the minimum 30mA is the maximum. It also talks about the potential for needing current limiting resistor's to protect the internal circuit. I'm not super well versed in all of this stuff. But it seems like it could be the problem. It also sounds like you really need more information about the bob and how much current it needs to process the signal. Can you check the hlfb to see how many mA you are getting at the board and then confirm with the board manufacturer that the number jives with what the board needs to change the state of the input?
  17. #657
    Oct 2009
    733
    Clamp on the hose from the machine onto the elbow:
    Attachment 419772
    Push the fiber glass rod through the hole on the elbow.
    DC system ready to be connected to the vacuum:
Name:	38 IMG_8017.jpg
  18. #658
    Aug 2018
    621
    Attachment 419764
    Attachment 419766
    I like what you're doing, much more elegant than the unitrack and hanging from the ceiling hose. I was originally thinking of doing something similar, but I got burnt out on working on the machine. Can't wait to see that thing cutting.
    Dan
  19. #659
    Aug 2018
    621
    You should ask for a example of one of them to see how they got it to work.
  20. #660
    Oct 2009
    733
Name:	37 IMG_8015.jpg
  1. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  2. CNC bench lathe or other small bench lathes
    By Scootworks in forum Turning Machines
    Last Post: 08-20-2011, 06:36 AM
  3. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  4. David
    By [email protected] in forum Fanuc
    Last Post: 12-11-2009, 08:56 PM
