586,096 active members*
3,378 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > TITAN DNC on PROTOTRAK
Results 1 to 11 of 11
    Feb 2019
    4
    Hi Ive got a Titan DNC units to use on my old PROTO TRAK MX3 CNC Mill
    Im having problems with it not completing a large 3D file
    Its generating a coms error about 3/4 away throw the file
    I think its something to do with the handshake the proto trak
    requires a XON XOFF on its setup it dosnt have this setting
    Can you help or do you have an idea of a product that may work
    Jan 2019
    74
    Did you get the 5 pin cable? hardware xon/xoff requires you cable to use the 5 pin configuration. I also just bought one of the Titan units for Fanucs. Love it. The guy I bought it from on ebay is quite knowledgeable.
    Feb 2019
    4
    Thanks butt no shore what you mean by 5 pin cable
    the cable Ive used is the one supply a DB 9 to DB 18 with a gender changer at the machine end
    I do look forward to trying it on my Funuc lathe
    Feb 2019
    4
    Thanks again for an idea were to look it may be around the pins that control ready to send an clear to send setting up a manual hand shack
    Jan 2019
    74
    There are 2 pin configurations for DNC. 3 and 5. Software control only requires 3 pins. Hardware requires 5. If you look up in schematics for DNC you will see. the difference in connections. Always get 5...just in case. A 5 pin works for both setups.
    Feb 2019
    4
    Thanks Ive ordered the right cable To blind these days to solder my own
    Jan 2019
    74
    LOL. That's why I order them, too. Plus, I don't have the patience to troubleshoot something that has a hundred variables, like DNC.
    Feb 2019
    5
    Nice
    You have a real ability for writing unique content. I like how you think and the way you represent your views in this article. Thank you for sharing.
    bubble shooter
    Mar 2020
    Re: Nice
    I don't know what to really say what you share very well and useful to the community, I think it makes our community much more developed. Conseils pour choisir votre clavier gamer.
    Jan 2020
    7
    Re: TITAN DNC on PROTOTRAK
    If you have a lot of patience there is no problem to fix everything. But you may have really a lot of patience.
    Jun 2021
    Geometry dash is a reaction-based game with just a single button. Your goal is to hop your little cube over or through various obstacles while listening to music tracks that have become so ingrained in my memory that I can recall them at a moment's notice. You die and must restart the level if you miss a jump or collide with an obstacle.
