586,645 active members*
1,896 visitors online*
Results 1 to 6 of 6
    Aug 2016
    4
    fanuc om starts from computer
    hi firends, we have taksan tmc700 that has fanuc om control unit. we connected from machine to computer. we may send and receive from computer to machine in edit button (i/o read and punch). our problem, how do we run on long program from computer. machine has not dnc, tape and drip feed button. a frend has another similar machine. he said that follow inc jog->auto->cycle start. we tried but not. machine has cycle start and output start.
    is there another solution our problem.
    Re: fanuc om starts from computer
    M51 turn on DNC.
    M50 turn off DNC.
    This works on my YCM machine but may not work on yours. Not sure if it's Fanuc derived or MTB.
    You also need DNC software. I use dnc4u.
    Aug 2016
    4
    Quote Originally Posted by the_gentlegiant View Post
    M51 turn on DNC.
    M50 turn off DNC.
    Thanks, I try. I have dnc program that name is Cimco.
    Aug 2007
    793
    check which signal turns on G127.5 coil in ladder
    G127.5 means DNC mode for Fanuc
    Aug 2016
    4
    Hi friend. I solved my problem. Solve: select MDI mode after parametre button press and pwe 1 input. Diagnos button press (under monitor) after find F296 parameter change to 00000100. This turn on dnc (tape mode). Moreover it change 00000000 turn of dnc (memory mod). Thanks
    Jan 2023
    Quote Originally Posted by pazarkaya View Post
    Merhaba kardeşim dgn f296 yı 100 olarak değiştirdim ama programı kart okuyucudan çalıştıramiyorum
    Biraz detay verebilirseniz çok sevinirim
  1. Replies: 4
    Last Post: 01-23-2022, 05:45 AM
  2. Replies: 1
    Last Post: 12-03-2018, 04:00 AM
  3. FANUC O-MD can't use DNC from computer
    By romanr9999 in forum Fanuc
    Last Post: 08-20-2018, 05:52 PM
  4. Replies: 2
    Last Post: 09-14-2017, 08:31 PM
  5. Fanuc 31i personal computer function
    By CNCCaptain in forum Fanuc
    Last Post: 08-15-2011, 11:12 PM
