586,055 active members*
4,376 visitors online*
    Problems with x and y axis
    Hi there i have baught a 600mm by 400mm 100w co2 laser but does cut to correct size ex. If i cut 160mm by 160mm it is about 2mm bigger, the bigger i cut the more the size is out dont know what to do i am using coral draw x7 and can not find any pulse settings thank you in advance.
    Jan 2008
    940
    Re: Problems with x and y axis
    There is a calcutator for this in your laser software you will need to go into your vendor settings and use it. Here is a small video of how to do it.
    https://www.youtube.com/watch?v=ZRXVhWA2kqk
  1. Y axis problems
    By cjbravo2 in forum Uncategorised WoodWorking Machines
    Last Post: 12-31-2016, 04:20 PM
  2. QT-25 x-axis problems
    By drlx3 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-15-2014, 08:06 PM
  3. X axis problems
    By bylu in forum DIY CNC Router Table Machines
    Last Post: 10-14-2012, 10:48 PM
  4. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  5. Z axis problems
    By Gregor in forum DNC Problems and Solutions
    Last Post: 04-25-2003, 11:23 AM
