586,069 active members*
3,858 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Viper 200 MPG Step Issue
Results 1 to 2 of 2
    Triump1 Guest
    Hi guys,
    When I step the wheel on my mpg, the table starts to move. However, if I turn the wheel so it clicks once, the table will move slowly. If I turn the wheel another click the table speeds up. So every time I turn the wheel, it increases the speed of the table instead of indexing the table one position as indicated in the hand wheel.
    Anyone have any ideas on why this is happening. I have tried everything A can think of.
    Feb 2007
    966
    Re: Viper 200 MPG Step Issue
    What controller are you using ?
  1. Viper 200 issue
    By jacklegjim in forum Viper Servo drives
    Last Post: 12-18-2018, 12:54 AM
  2. would Step Angle be an issue for changing stepper motors
    By gokhanduman in forum Stepper Motors / Drives
    Last Post: 07-19-2017, 06:35 PM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. Viper 200 Issue
    By Trucks in forum Viper Servo drives
    Last Post: 12-20-2011, 04:09 AM
  5. LARKEN viper.100 (step/dir) on EMC2
    By krummigudna in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2008, 09:26 PM
