586,036 active members*
3,695 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Sep 2009
    135
    Re: TC22 from BT40 to CT40
    Apologize for the confusion. I never said I did the conversion. I had a cat 40 tool that I used in My BT machine. I change that to out by hand. I do not have the tool anymore but I kept the pull studs in case I ever needed them again.
    I'm not sure what else you would have to change out to do the conversion. I did see a forum post that talked about doing the conversion some years ago. I know the tool change height needs to be adjusted when you switch to different tool holders.
    Sent from my SM-G955U using Tapatalk
  2. #22
    Dec 2009
    521
    Quote Originally Posted by cooperjm View Post
    Kind of a follow up.
    I bought a whole bunch of CAT40 tool holders. The owner had a HAAS machine. Guess what? When you hold the CAT40 holder with the HAAS pull stud up against a TC22 BT40 holder and its pull stud, the CAT40 looked like it would work dimensionally. SO, I popped into the TC22 spindle and it popped right in. So, now I need to commit to buying the CAT40 Grippers from EMI...ouch....I'll probably sell my BT40 grippers.
    Marty
Page 2 of 2 12
  1. Big Plus CT40 in CT 40 Haas VF-2
    By williamcan in forum Haas Mills
    Last Post: 02-02-2019, 07:24 PM
  2. BT40 tooling in a CT40 toolchanger and spindle?
    By rpseguin in forum CNC Tooling
    Last Post: 01-28-2019, 04:31 PM
  3. GILDEMEISTER N.E.F CT40
    By sting007 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-17-2014, 12:44 PM
  4. Problems at CT40
    By Nummer8 in forum SERVICE FOR CNC-MACHINES
    Last Post: 02-10-2011, 07:59 PM
  5. CT40 vs. BT40 spindle's and tooling?
    By gunsmither in forum Haas Mills
    Last Post: 01-09-2007, 05:06 AM
