586,103 active members*
3,804 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Dec 2009
    521
    TC22 from BT40 to CT40
    On the Bridgeport Torq Cut 22 machines, to switch over to CT40 tooling, is it just a matter of changing out the Carousel grippers to CT40 grippers?
    Marty
    Sep 2009
    135
    Re: TC22 from BT40 to CT40
    You also have to change the tool change height. You need a different pull stud for the ct40 also.
    Sent from my SM-G955U using Tapatalk
    Dec 2009
    521
    Quote Originally Posted by cooperjm View Post
    Thanks, that part seems trivial.
    Sep 2009
    135
    If you buy all 22 segments from EMI, they're around $25 each.
    Dec 2009
    521
    How old is that price?
    Sep 2009
    135
    Couple weeks ago. I bought a whole Carousel worth of segments..
    Dec 2009
    521
    Thanks!
    Marty
    Dec 2009
    521
    What pull studs does the TC22 use for CAT40? Is there a drawing out there somewhere or mfg. and part number?
    Marty
    Sep 2009
    135
    I have some. I can send you pictures an dimensions next week.
    Dec 2009
    521
    Sounds good. Thanks
    Marty
    Dec 2009
    521
    Is this it?
    Also, to be sure the spindle can accomodate both, BT40 and CT40, the only difference in the change over is the pull stud and change out the grippers in the carousel?
    I just got a nice deal on a bunch of CT40 tool holders locally. I didn't have any tool holders yet. The deal was good enough for me to change out the grippers, I would have needed the pull studs anyway.
    Marty
    Sep 2009
    135
    No, that is not it. It looks just like the. but it has 5/8 11 threads on it. It is also shorter then the BT pull stud. I will get you a picture and dimensions when I get home this evening.
    Dec 2009
    521
    So this one but with 5/8" threads:
    Sep 2009
    135
    Yes. Dimensions C will be shorter for the CT tool holder.
    Dec 2009
    521
    This is the closest I found, overall length is a bit shorter as well.
    Thank you!
    Dec 2009
    521
    I'll wait until you get home. I sent an email to EMI as well.
    Don't want to mess this up.
    Thank you!
    Marty
    Dec 2009
    521
    Here is what Aaron at EMI said about swapping from BT40 to CT40:
    "There is way more involved in that. We have had our serviceman do a swap once and between parts and labor (you need a service man very familiar with this tool changer setup) it was well over a $6000.00 event and this was in 2010. That is not a project we would recommend taking on. In fact, you can buy a used Bridgeport machining center ready for CT tooling for the cost of what it would take to change from BT to CT."
    Dec 2009
    521
    Any news on the dimensions Cooperjm and the statement from EMI? I can't see why it wouldn't work other than the threads for the CT40 tool holder the dimensions are otherwise the same?
    Marty
    Sep 2009
    135
    Marty
    I just spent 30 minutes looking for those to pull studs that I have. I cannot locate them at this time. I do apologize.
    If you go look up the taper length 4bt 40 compared to a cat 40 that different should be similar to the difference in the pool stud length.
    I know Aaron and Mark a EMI. I believe that they have experience with this that I do not. I do know that I put a cat 40 with a short stud and my spindle. I cannot guarantee what the drawbar pressure was though.
    Dec 2009
    521
    Marty
    I'm confused. So you did do this conversion or not?
    Is the pull stud the same as the BT40 with the exception that it has the 5/8"-11 thread?
Page 1 of 2 12
  1. Big Plus CT40 in CT 40 Haas VF-2
    By williamcan in forum Haas Mills
    Last Post: 02-02-2019, 07:24 PM
  2. BT40 tooling in a CT40 toolchanger and spindle?
    By rpseguin in forum CNC Tooling
    Last Post: 01-28-2019, 04:31 PM
  3. GILDEMEISTER N.E.F CT40
    By sting007 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-17-2014, 12:44 PM
  4. Problems at CT40
    By Nummer8 in forum SERVICE FOR CNC-MACHINES
    Last Post: 02-10-2011, 07:59 PM
  5. CT40 vs. BT40 spindle's and tooling?
    By gunsmither in forum Haas Mills
    Last Post: 01-09-2007, 05:06 AM
