586,071 active members*
4,360 visitors online*
    Sep 2013
    10
    Vertical CNC Bandsaw
    Has anyone ever built or purchased a vertical cnc bandsaw? I have googled a few videos but have yet to find any information. I have built a couple hobby routers and would like to build one. I am currently milling a single profile out of huge oak timbers and it would greatly decrease time if I could do a one pass profile with a bandsaw. Building or modifying an existing bandsaw shouldn't be an issue but unclear how to program the blade angle axis.
    Apr 2004
    Re: Vertical CNC Bandsaw
    The commercial CNC Vertical band saws for wood have guides that rotate and twist the blade you would need to twist the blade tangent to your required cut profile and then move either the saw or material along the cut direction.If you are milling large timbers may I suggest mounting your band saw on casters and using it like a very large Jig saw while supporting your timber in a fixed position. I did this years ago to put decorative ends on some very large roof joists.not as much fun as designing and building your own new machine but maybe more practical.
    Cheers
    Karel
  1. Best Vertical Bandsaw Under $1000!!
    By MIATuner in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2012, 08:06 AM
  2. Looking for a 7x12 Horizontal / Vertical Bandsaw... Recommendations?
    By PhoenixMetal in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2009, 01:30 PM
  3. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
  4. Small, *vertical* metal bandsaw? cutting 12 ga 304 ss sheet...
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2007, 03:30 PM
