586,105 active members*
3,268 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How many axis to DRO on a Milling machine?
Results 1 to 6 of 6
    Mar 2006
    62
    Just found a Anilam Wizard 4 axis Dro for my milling machine.
    With X and Y on the Table and Z on the knee what would you use the 4th axis for?
    The mill has no quill feed but it looks like the DRO can take an input from a rotary encoder so would it be worth trying to set it up to show rpm of the head / tool?
    The mill is a denbigh varispeed so as the speed is infinatly variable I thought it may be a usefull function.
    The vertical head also rotates 360 so it may be more usefull to fit the rotary encoder to that to show angles.
    What do you lot have your 4th axis fixed to? Apart form quill feeds?
    Thanks!
    Oct 2006
    157
    Do x and y on the table . Z on the quill and the other one for the knee.
    Most or us use the 4th axis for a rotary table. A Phase 2 rotary tables have proven fairly good for this procedure.
    Ken
    Kenneth A. Emmert
    SMW Precision LLC
    Spokane, WA
    866-533-9016 Toll Free
    Mar 2006
    62
    I don't have a quill feed on my baby.
    Keeping it free for a rotary table is a good idea.
    I will proabally end up with an older, manual rotary table. Is it fairly simple to add an encoder to it?
    Oct 2006
    157
    Hmmm, I like the rotary table idea !
    Mar 2006
    62
    Flicking through the on screen settings on the dro,
    it looks like you can set any of the axis inputs to linear or rotary.
    When you chose 'rotary' you have to tell it how many 'steps' your encoder makes per revolution.
    No, I have a scope that can record the wave from an encoder so maybe if I could mount an encoder to a rotary table using something like a rubber wheel that will turn the shaft with the table..
    I could rotate the table a full 360 and count the steps then give this info to my dro.
    If it was simple enough to set up I could have my 4th axis showing as a 'degrees' on the rotary..
    I am trying to find a manual for the dro at the moment.. :-)
  1. need help with tos milling machine
    By derkiow in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2021, 03:33 PM
  2. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  3. 5 axis milling machine
    By toneV8 in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2005, 11:11 AM
  4. Replies: 3
    Last Post: 05-18-2005, 05:15 PM
  5. D&M Milling machine
    By mrand in forum Benchtop Machines
    Last Post: 03-11-2005, 09:58 AM
