I need a total of 6 pieces using 6061-T6. The flat pieces are 1/4" thick. The rings are 35mm thick. They will have 80mm OD bearings inserted so the bore must be a fairly high tolerance (not press fit but snug). I have never worked with DXF files before, so please let me know if there is additional data needed. You supply the stock.
Thanks in advance.
Lee
