586,798 active members*
3,308 visitors online*
Results 1 to 6 of 6
    May 2003
    267
    Machining Mild Steel
    I need to machine some mild steel. I know that in order to machine mild steel, the spindle rpm must be set very low. I have tried using a variable router speed control, but with this setup my routers minimum speed is about 8000 rpm. My question is, what is the speed range for machining mild steel (drilling holes, etc)? Also, what type of motor do I need? I have considered using an order hand drill with a variable speed control device. This setup does slow the rpm's down, but the torque at low speeds seems little. Any advice?
    4826
    George,
    If you are using High speed steel tools (such as drills), you need to limit the largest circumferential speed of the tool to 100 (or less) feet traveled per minute. For a 1/4" diameter tool, this would be about 1500 rpm. The forumula is:
    1200/(Pi * tool diameter).
    For carbide tools you can run 3 or 4 times faster.
    A variable speed drill would put you in a much better speed range. You might want to use a 3/8 or 1/2 rated drill, in order to get sufficient gearing to do something. Mind you, none of those tools have spindles or chucks that are made for the side loads of milling, but you can certainly drill with them.
    Nov 2003
    79
    I have been taught that you never put a mill in a drill chuck
    Jul 2003
    41
    I didn't think you where supposed to put an electric drill on a router either. I think a milling cutter in a drill chuck is going to be the least of George's problems. George, I know next to nothing about routers but make sure you have a ridgid setup and can feed slowly and accurately at the same time.
    Good luck,
    Jim
    www.picopascal.com
    Mar 2005
    60
    Try out-sourcing your job to a professional shop, no offence but if you guys are talking about cutting mild steel with a drill press or such then you guys are just asking to loose a finger or two.
    Oct 2004
    107
    8000 rpm can work. Are you using a cnc or manual mill, what are your maximum cutting speeds etc. FWIW I just milled a 6x8x2" block of 4130, takeing 3/4 of the material weight out. I used 7000 RPM 36 ipm, .04 stepover, and .05 depth of cut with a ball end mill. The finish pass was in the high speed spindle, 25k rpm, 1/4" ball end mill .01 step over, .01 depth of cut, 82ipm.. Both were cut dry with air blast, with OSG exo carb endmills.
    More info is really needed on you setup to get you some better advise.
  1. A Mill for milling HSLA and Mild Steel
    By deep_drill in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2005, 05:29 AM
  2. Comparing aluminum extrusion to mild steel
    By coolman in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 12-10-2004, 04:19 PM
  3. Cnc Machining 1/8 thick steel sheets
    By ccm in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2004, 08:47 PM
  4. aluminium and steel machining
    By Hobbiest in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2004, 04:59 AM
  5. Machining 1020 Steel with Inserted Cutter
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-26-2004, 03:26 PM
