586,094 active members*
4,110 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Axis amp replaced - now I get strange sound from axis motor
    Apr 2012
    49
    Hey there,
    Just replaced x axis ampon my VMC15xt (the old one was amc, the new one is glentek), everything works, I get some kind of sound from the axis motor (to me it sounds like a water running through some pipe). The noise is present as soon as I power up the machine, no matter if I move the axis or not.
    Haven't try any machining yet.
    My guess is it has something to do with those little pots, and tunning the amp. Any advices? Anybody has some kind of procedure? Thanks a lot, guys, you helped me a lot up to this point.
    Jan 2014
    20
    Re: Axis amp replaced - now I get strange sound from axis motor
    Do a Google search for "fadal axis ballance program "
    I found a pdf that has the factory service programs. You'll have to scroll through to find the one you need.
    Apr 2012
    49
    Quote Originally Posted by Beltdrive View Post
    Thanks, man.
    Already had that pdf - found very quickly what you suggested.
    It turns out I already have most of the needed documents - only I don't know what is usefull and what do others use in work.
    Apr 2012
    49
    I bought the amp from K-mac parts, i think that was your advice in one of previous posts. Thanks for that, they were very professional, and the amp works. I just need to tune it a little bit. Thanks for making me better at understanding my machine and keeping me going when I hit the problem.
    Jan 2014
    20
    I'm glad that I could help.
    I really like the fadals and I think the DC machines runs smoother than the later AC drives.
    I switch between 3 different A axis drives and reballancing the amp is part of it.
    Balancing the other axis are basically the same.
    I have 3 fadals as well and the amps arent identical. Some are more clearly marked.
    You'll need to adjust the sig. and bal pots to what the service program says.
    I like using a volt meter between pins 2 & 3 on one machine and on the other machine I go to ground and it's either lead 2 or 3. I don't know because the wires aren't labeled as the other.
  1. strange pulsating noise from x axis motor
    By LEARN in forum Charter Oak Automation Support Forum
    Last Post: 05-31-2015, 06:15 PM
  2. X-axis motor replaced -> problems
    By FinnCNC in forum Fadal
    Last Post: 08-20-2008, 10:13 PM
  3. Replies: 6
    Last Post: 07-16-2008, 03:16 AM
  4. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
