586,100 active members*
2,676 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Need to know if possible to used computer and motor drives on two different machine
    Cool Need to know if possible to used computer and motor drives on two different machine
    I am converting my vertical mill to cnc, I want to know if i put all control in one mobile cabinet can I used on diy cnc router and mill. by just getting more stepper motors for diy router [plug controls into ether machine} thanks hope to recieve input
    Mar 2015
    410
    Re: Need to know if possible to used computer and motor drives on two different machi
    You can use the controller cabinet on more than one machines. If you are going to connect and disconnect often, you need good quality connectors. Use identical motors on both machines so you don't need to adjust the drivers each time. Use a separate setup/configuration file for each machine. Power off and disconnect from the supply (wall outlet) before you (dis)connect a machine.
    Feb 2019
    yes, we can control the machine using the computer but its not a complete computer its microprocessor contain with some certain commands thithesemmands are regulating this system is called PLC ( Programmable Logic Controller ) now IPCS Automation providing PLC Training in Chennai
    Oct 2020
    Digital Marketing Course in Patiala - If you are the one who is searching to find out the best and No.1 Digital Marketing Training Institute in Patiala, then PIIM is the one you can go with.
  1. Viper 100 drives >c11 bob>computer
    By Tool bit in forum Viper Servo drives
    Last Post: 02-22-2010, 07:02 PM
  2. help info on VFD-motor-computer
    By wilkomedic in forum Phase Converters
    Last Post: 04-29-2009, 03:34 AM
  3. motor and drives how far apart can they be
    By reeftoker75 in forum CNC Machine Related Electronics
    Last Post: 09-23-2007, 01:33 AM
  4. One box or two? Drives and computer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 04:08 PM
  5. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
