586,069 active members*
3,484 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Current MESA hardware recommendation for AC servos
Results 1 to 8 of 8
    Jan 2016
    120
    Hi guys,
    I have a pretty quick question. MESA has a large number of offerings - what are the best hardware options for running AC servos with LinuxCNC? Also, is there a performance difference between the ethernet and PCIe offerings? I haven't chosen the 1kw servos/drivers yet, so I could be flexible in that regard.
    Thanks for your recommendations!
    Micah
    Feb 2008
    644
    Re: Current MESA hardware recommendation for AC servos
    What type of machine are you driving?
    Jan 2016
    120
    It's a Novakon Pulsar, but I'm getting servos on it. I haven't decided which servos/drives to use. It'll be 4 axis, but I'm hoping for some room for expansions in the future.
    Are there general pros/cons between PCIe and ethernet main cards? Also, what about the 50 pin vs DB25 vs serial daughter cards in general?
    Thanks!
    Feb 2008
    644
    If this is for PathPilot I'm not sure what hardware is compatible other than 5I25/6I25 and 7I92.
    you have a wide range of 25 pin daughterboard types available for these
    If this is for LInuxCNC, I would probably chose a 7I96 if 11 4-36VDC inputs and 6 0-36VDC 2A outputs is sufficient.
    (these are in addition to the 5 axis of step/dir, 1 channel quadrature encoder input and serial + parallel expansion)
    There is no significant difference in PCI/PCIE/Ethernet performance. Ethernet has the advantage of allowing the PC to be
    any practical distance from the control electronics and provides electrical isolation. Ethernet also allows use of small PCs with no slots
    Jan 2016
    120
    Thanks! This will be for LinuxCNC. Is their a performance difference between the serial and parallel daughterboards? For instance, will the 7I94 loaded with 7I83s operate differently than say a 7I80DB/7I77?
    Feb 2008
    644
    No, there is no real difference
    Jan 2016
    120
    Quote Originally Posted by PCW_MESA View Post
    Awesome. Thanks for your help figuring this out!
    Jan 2009
    334
    Quote Originally Posted by burbingus View Post
    Hi guys,
    Micah
    I refitted a Denford NovaTurn to Yaskawa 100W AC Servos.
    The system is using +-10V in Torque mode.
    The system is as follows:
    AMD GizmoSphere I
    IBOB2 interface
    MESA 6i25
    MESA 7i77
    PathPilot
    Iron-Man
  1. Mesa Control Card Recommendation
    By JackDavies in forum LinuxCNC (formerly EMC2)
    Last Post: 06-23-2017, 05:18 AM
  2. Replies: 5
    Last Post: 04-29-2017, 10:09 PM
  3. MESA hardware that uses Eithernet instead of 5i25 and DB25 cable?
    By kmcwhq in forum LinuxCNC (formerly EMC2)
    Last Post: 03-27-2016, 01:05 PM
  4. Machine control software and hardware for RS-232 servos?
    By PaulMakesThings in forum Servo Motors / Drives
    Last Post: 11-23-2014, 03:08 PM
  5. EMC2 I/O Hardware Recommendation
    By Liberty4Ever in forum LinuxCNC (formerly EMC2)
    Last Post: 12-25-2011, 06:31 AM
