Ok i have looked around the web and havent found any good plans for Flip Pods. Has someone ever built a FLIP POD table for there router. Seen a few pics seen a few prices. But $1500 for a 100 pod carter system is way out of my price range. Would like to make a setup to do parts as small as 2"x2" with holes in it out of a 4'x8' sheet. then flip them around for a whole new setup. Have a 3hp Gast Vacuum pump 50cfm and 24" hg a 60 gal reserve tank.
Also seen a german setup that uses a membrane you put on there pods and you can cut thru it with out loss of vacuum. Also has a 1 use membane option.
VacPress would love to see your idea for a set up.
There is alot of smart people out here in cnczone land. Just need to talk to the right one.
Donny
