586,102 active members*
2,541 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Pulley and Speeds for 2 meter long X axis.
Results 1 to 3 of 3
    Nov 2018
    53
    Greetings guys!
    So I'm back, going to work on my X axis which is built on a 2 meter long by 300mm Aluminum I beam. I am waiting on some HTD 5M x 15mm wide belt. I have my mounts for Idler and pulleys to work on. I went with a 12mm shaft (bore) to make sure things are strong. and a Nema 23 3 N.m motor
    So here is where I am. What are typical speeds used for the X axis on a large machine like this? This is more non-contact like a plasma, than driving a spindle in Aluminum.
    I ask because I'd like to know what tooth count of pulley I should get/make?
    Less teeth, I would have more accuracy but less speed. More teeth and I get more speed but lose some torque.
    I 3D printed a 30 tooth pulley just to see the size.
    What's more typical.
    Thanks!
    35538
    Re: Pulley and Speeds for 2 meter long X axis.
    Speeds would be very dependent on the specific application. Could be anywhere from 10-100 meters/min, or even faster.
    Dec 2013
    5717
    You are kind of trying to work the problem backwards
    Normally you start with the needed speed, then factor in the load, desired acceleration, system resolution, and then finally arrive at the motor requirements and the pulley sizes.
    At this point, figure out what you can live with for speed and resolution, and gear the system accordingly. You may have to sacrifice some speed for resolution.
    Jim Dawson
    Sandy, Oregon, USA
  1. Help specifying 2 meter long Ball screw for Z axis...
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 01-09-2019, 06:14 PM
  2. How Long DOES IT TAKE FOR A laser cutter to cut a meter of cardboard?
    By pichaku in forum Want To Buy...Need help!
    Last Post: 10-16-2016, 09:48 PM
  3. Optimizing milling feedrates and speeds - watching the spindle load meter
    By PhoenixMetal in forum Uncategorised MetalWorking Machines
    Last Post: 03-06-2009, 02:57 AM
  4. Speeds for cutting metals relating to pulley size?
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-16-2006, 02:11 AM
  5. TAIG spindle speeds and a load meter question
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 04-26-2006, 10:34 PM
