586,072 active members*
4,645 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Help required producing usable Gcode files for CNC engraver
Page 1 of 3 123
Results 1 to 20 of 45
    Jun 2008
    91
    Guys, I have made a CNC engraver that I plan to use to produce fascia panels in MDF for some homemade gaming rigs, plus later use in conjuction with a 25w laser to cut MDF panels for some bits for construction of consoles etc. It works great, I'm using Universal G-Code sender and with some test gcode files I downloaded from the internet have checked it out and calibrated it.
    My problem comes when I try and port my own designs to it. I have Autosketch, where I can produce exactly what I want and eport to a .dxf file. I have Qcad, which allows me to convert that to a .svg file. Using Inkscape I then convert that to g-code. Or at least that's the theory.#
    in practice the conversion to g-code simply doesn't work. It always comes up with errors, and if it saves the file at all (50% of the time max), the G-code is not useable and it fails to work on the CNC engraver. To test which bit of it was the problem, I opened a new document in Inkscape, drew 1 single circle on it, then followed the process where you convert objects to paths, and finally converted it to g-code - but it comes back with errors. With one simple geometrical shape.
    The files I want to engrave are not extravagant and I am so close but the failure of this last step has completely stymied me. For the sake of the last percent, all the rest is worthless.
    I've attached (or at least I think I have!) a .dxf file that I was trying to use as a test. You can't see the .svg file produced from it as it's not an allowed file type. When I tried to save it as g-code this was the error I got 'Drawing out of range: [5.000000054166666, -10.00000009774999] [125.00000003124998, 89.99999992725] No points.'
    At least, that was the error that time.....
    I need a reliable way to turn my files to g-code otherwise my whole lot of work is a waste, so if anyone can help me I would be eternally grateful!
    Les
    Dec 2013
    5717
    Re: Help required producing usable Gcode files for CNC engraver
    Try CamBam to create the G code CamBam CNC Software
    CamBam reads the DXF file directly and creates the G code
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2019
    7
    I use CamBam also. The PP was tweaked from (M3Cutviewer) in order to work on my Biesse Rover J (7ATC). For a simple CAD/CAM program, the control options for machining are plentiful.
    Jun 2018
    362
    Tested your DXF file with SimpyCam from MR-Soft Nc Software Tools and it generates G-Code just fine for my Mach-3 Postprocessor settings.
    Successfully created a sample file using my defaults (metric) to produce a drawing of 4 x 3 mm (so I gather this should be in inches?) :-)
    I won't post it here but can e-mail. Send me an address via PM if you would like to test it. I can try inches if you like.
    Dec 2013
    5717
    I created the attached G code file from your DXF, it is in Imperial units. I can convert to metric if needed.
    Attached Files Attached Files
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2018
    362
    As a curiosity I compared the code Jim posted to the code generated by SimplyCam.
    Jim's CamBam code is about 4900 lines. SimplyCam code (including additional comments for before and after feed moves) is about 450 lines.
    Interesting :-)
    Dec 2013
    5717
    Quote Originally Posted by he1957 View Post
    Interesting :-)
    Oops, you are correct, wrong post processor, has Arcs to Lines turned on. You'll note that there are no G2 or G3 moves in the code I generated. For some stuff I do it that way.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    Thanks guys, so it must be something to do with the Inkscape plugin for Gcode. I'm having a play with CamBam and first thoughts are that it is good, just want to check if it works for me before buying it. One curiosity that I have already discovered is that I have three text boxes on the DXF file, yet on this .nc gcode file, one of the text boxes (upper left) disappears - is that due to the restrictions of the trial version?
    Cheers
    Les
    Jun 2008
    91
    Even more bizarre now, despite the image showing the correct size in millimeters in the viewing pane, sometimes the Universal Gcode Sender outputs the file as if it was reading the imperial units as the millimetric value, and then the next time it doesn't. I managed to resolve one of the reasons for the router not wanting to work, the z travel limit had somehow reset to zero, and the only way to recover it was to edit the firmware settings file. However the random switching between unit types has me stumped. When you go to open a file it also tries looking for some bizarre location in the PC, even though that location doesn't exist, so it comes up with a dialog box saying it can't find it, which you clear and immediately pops back up again. Clearing it a second time gets rid of it until you try to change the path you want to open, then repeats before finally showing you where you want to see
    I'm totally confused, and am close to throwing in the towel. Even CamBam doesn't seem to like me, despite repeated attempts with CamBam, I cannot get the third bit of text to show up on a gcode file where it shows up on the dxf and CamBam files.
    I'm uninstalling it all and will do a laptop brainwash and try again, but this is seriously frustrating especially as what I want to do is relatively simple....
    *sigh*
    Les
    Dec 2013
    5717
    Quote Originally Posted by lesthegringo View Post
    Cheers
    Les
    Could you post the DXF file? Or are you using the same file as above?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    here is the CadBam file I used to generate the gcode appended to have a .txt extension (the only way I could get it to attach). You will have to rename it as a .cb file for it to work of course, but you will see that it has three items of text
    Thanks for the help
    Le
    Dec 2013
    5717
    The CB and NC file is attached
    The text came up fine on my screen. The one thing I did was to select everything, right click, EDIT, JOIN. This converts everything to polylines and joins connected lines and arcs. Makes things a little cleaner and somewhat reduces the NC file size. I used the standard Mach3 post processor.
    I have not test run the file on my simulator so I don't know what the real output looks like.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    Straight away this is better; it is using the correct units (or at least is sized correctly) and all the text is there; obviously no tool retraction but I can see that it worked way better
    did you you do anything to make the sizing issue go away?
    Cheers
    Les
    Dec 2013
    5717
    That is strange, it looks like it is transposing X and Z for the tool retraction, G0 X0.5 should be G0 Z0.5 I may have set up that post processor for lathe work when I was doing some testing. I never use Mach3 so sometimes I play around with that post processor. Glad you caught that.
    No, I did nothing for the units or sizing. It's set up to default to Imperial units.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    Ok, thanks - I wonder why my setup got its drawers in a twist over the units? I will have to try and stick to one or the other, and in Autosketch (used for the original dxf files) I could switch between the two easily, so the electronics were done with that.
    Qcad looks like a modern alternative, not as easy to use to be sure but I'll have to get over that
    Thanks again for the help
    Les
    Dec 2013
    5717
    It was a post processor setting, I had it set for the Clearance Plane = X rather than Z
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    strange, all the curves have become irregular polygons, at least once on UGS
    Something on my PC maybe?
    Les
    Dec 2013
    5717
    No, it's not your PC, it's the way the arcs are set up in the post. There are several different ways of describing an arc in G code, and the method that I chose in the post is apparently not compatible with your program.
    There may be a switch in your program that would correct the display, but the best way is to set up the post to be compatible with the default setting that you need.
    If you start with the CB file and then in the lower left pane click Machining, and go to the Arc Center Mode and select default it may be correct. Then repost the file.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    91
    got it, thanks. I'm using Universal Gcode Sender at the moment, but I'm open to any suggestions if there is better out there. I tried GRBL Candle, which worked once, then never worked again, plus a couple of others that seemed to be finecky to set up for my application and hardware, but UGS seemed to be pretty good so I stuck with it
    Cheers
    Les
    Dec 2013
    5717
    Cheers
    Les
    Sorry, can't help you there. I either use my local network, a USB stick, or the cloud to transfer the files to my machines. All of my machines also have CAD and CAM right on the machine computer so I can create, edit, and post files directly to a folder then from there open the NC file in the CNC program.
    Jim Dawson
    Sandy, Oregon, USA
Page 1 of 3 123
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Any usable Les Paul 3d files?
    By mmcguire in forum Musical Instrument Design and Construction
    Last Post: 01-02-2020, 05:41 PM
  3. BobArt - Converting plans to usable CAM files
    By bschatz in forum BobCad-Cam
    Last Post: 10-18-2012, 09:00 PM
  4. Replies: 3
    Last Post: 11-23-2006, 05:49 PM
  5. G-code files are required
    By uav in forum G-Code Programing
    Last Post: 08-26-2006, 10:38 AM
