586,052 active members*
4,357 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Red "fault" light is lighting on my G540.
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Mar 2007
    2083
    Re: Red "fault" light is lighting on my G540.
    loose connections can easily cause damage to stepper drivers
    when energised
    the breaking of any motor connection will result in a back emf in the disconnected coil that is many times the supply voltage -
    destroying the output transistors that control the current that flows through the motor coils
    John
  2. #22
    May 2006
    309
    OK, I understand!
    So maybe it will be better to solder the wires from the drivers directly to the stepper wires instead of using a plug in that area in order to prevent damages like that?
  3. #23
    May 2006
    309
    I tried another time with a new driver and this time the same happened when I turned the tuning potmeter all the way to one end in order to get rid of the ticking noise, so I believe it was the same that happened last time. Does this potmeter regulate the current or voltage in a way that can damage the driver?
  4. #24
    Mar 2007
    2083
    which version of the G540 do you have ?
    if its the new type as in this video
    they potentiometers have a plastic body as seen at 1:27
    https://www.youtube.com/watch?v=Y2fPmjeaHFk
    Attachment 412628
    on older versions the potentiometers are uninsulated and on the G250 boards
    you have to avoid shorting the potentiometer or near by components to the case
    old version of G540
    Attachment 412630
    old G250
    Attachment 412626
    John
  5. #25
    May 2006
    309
    I have the old version without plastic body. Do you know which components it is which has been damaged? It will then be much cheaper to change some components than a whole driver.
  6. #26
    Mar 2007
    2083
    unfortunately I don't have any component level details of the Gecko stepper drivers
    Its a question you will have to ask Marris at Geckodrive.com
    John
Page 2 of 2 12
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. G540 fault light...what does that mean?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 03-07-2011, 02:37 AM
  4. GECKO G540 - Stuck in "FAULT" mode.. HELP!?!
    By CNC74 in forum Benchtop Machines
    Last Post: 02-06-2010, 09:37 AM
  5. New member with a "Fault Light" question.
    By kweitz in forum Community Club House
    Last Post: 09-05-2009, 04:32 PM
