586,089 active members*
3,821 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Red "fault" light is lighting on my G540.
Page 1 of 2 12
Results 1 to 20 of 26
    May 2006
    309
    It has worked until today when I coupled a rotary drive stepper to it. I have tried to remove the A-axis wire from the drive, but it´s still the same. I can reset Mach3, but when I push the buttons, only the numbers on the screen are running but not the steppers.
    What may be wrong?
    Mar 2007
    2083
    Re: Red "fault" light is lighting on my G540.
    when the RED LED is on all 4 G250 stepper drivers are disabled
    ( the signal that turns the GREEN LED on also enables the stepper drivers )
    its possible a faulty connection to the A Axis has damaged the A Axis driver and is triggering the E-stop / over current circuit
    I would disconnect all motors and check you can clear the fault ( just in-case its not the A axis that's the problem)
    if you then get the green light , connect one motor at a time until you trigger fault so you know what is the problem
    if the RED LED is on with no motors connected
    contact Geckodrive.com
    they will probably talk you through the disassembly of the G540 and removal of the four G250
    drivers to find the faulty one that need repair / replacement
    that will enable you to use the G540 as a 3 axis driver while your waiting for the fourth G250
    ( the G540's case is just clipped together the motherboard with all of the external connectors is plugged onto the four G250 boards that are screwed to the lower half of the case )
    picture taken from geckodrive web site
    alternatively they will give you instructions for you to return the G540 for them to test
    John
    May 2006
    309
    The charge pump has always been off. The voltage is 44V and when I took a quick on/off measurement of the current, it meassured 12A, so it should be more than enough. If I open the black box, can I then find out more? Will it be possible to remove some of the drives from the others in order to find the reason?
    May 2006
    309
    I removed all the wires, but the red light was there yet. I have also removed the paralell port cable, but still the same. Can it be that the power supply is damaged and doesn´t deliver enough current?
    Mar 2007
    2083
    with the parallel printer cable disconnected you will need to switch the charge pump to off ( switch to the right of the printed logo on the G540)
    what powersupply are you using ?
    with no motors connected what is the voltage you measure at the power supply terminals ?
    John
    May 2006
    309
    I didn´t measure the input current to the drives, but the short cut current of the power supply. I have now removed the drive for the A-axis and the green light came back, so I think something must have been wrong with the rotary stepper motor or maybe the wiring. Are there any ways to troubleshoot that case?
    Mar 2007
    2083
    44V is OK (it is within the 18 to 50V limits )
    with no motors connected you should not see 12A going into the G540 even taking into account current waveform will cause an inexpensive multimeters reading to be inaccurate
    with the cover off you will be able to unplug the main board from the four drivers and test the board on its own
    you will see each G250 driver is fastened to the base with 2 screws -
    note the G250 FET transistors and voltage regulator is only insulated by the black anodised coating, be carefull you don't damage the coating
    assuming the main board tested OK
    remove 3 drivers plug the main board onto the remaining driver
    if that works add another driver and retest
    repeat until you find the faulty driver (or all 4 axis are working)
    john
    Mar 2007
    2083
    have you have used the rotary axis stepper motor before ?
    I expect either the cable has been crushed so 2 wires shorted
    or you have a wire break that could be intermittent with just the insulation holding the broken ends of the wire together
    with the power on ,
    the back EMF generated when a motor coil is disconnected is high enough to destroy the stepper driver H bridge transistors
    while you can have a wire break any where
    the odds are greater where the wires exits the 9 way plug or enter the motor
    with a basic multimeter its not always easy to see the increased resistance of a dry joint
    when the resistance of the cable and motor winding is a few ohms and can be comparable to the contact resistance of the meter probes
    several times at work
    I have had inconclusive resistance measurements while checking multicore camera or audio cables
    cutting the last inch or two ( 25 to 50mm) off each end and soldering the connectors back on solved the problem
    John
    May 2006
    309
    I used this motor several years ago, but with another driver and I have resoldered the wire to the gecko plug after that, so maybe I have done something wrong there. The wire has also a middle plug connection near the motor which has been disconnected these years, so maybe some of the pins in this plug have been covered with an oxidation.
    Can I test the motor and the wiring with a stable dc current in any ways?
    Mar 2007
    2083
    do you have the data for your motor ?
    do you have a bench power supply with a variable voltage output and current limiting ?
    stepper motors will not run when connected to a DC supply
    what you can do is either apply the DC voltage as on the data sheet or label to one of the motor coils in turn and measure the current that flows
    or set the power supply current limit to the current stated in the data and measure the voltage across the coil
    for example if the motor data gave the coil resistance as 2 ohms the current as 3A and voltage as 6V
    connecting a motor coil to 6V DC will result in a current of 6/2 = 3A
    if the power supply is set to provide a constant current of 2A the volt drop across the motor coil will be 2 x 3 = 6V
    using a spare 9 way socket to make it easy to connect to the 9 pin plug on the cable
    you can measure the voltage across the motor coils and then at the 9 way D-type plug
    the volt drop across each coil and each pair of wires should be the same
    in addition you will need to check for short circuits between pins 7 & 8 (coil B- and A+)
    and pins 1 to 5 and pins 6 to 9
    did you fit heat shrink sleeving in the wires to insulate the terminals ?
    Attachment 412060
    if you have used a single resistor to set the motor current its easier to insulate the terminals than trying to solder 2 resistors in parallel
    one possible problem you can have when you solder stranded wires to the bucket terminals on the 9 pin plug
    solder can wick up inside the wire and when its flexed the wires break where the solder stops
    John
    May 2006
    309
    Motor label: KL23H251-24-8B When I tested the wires there was a difference between the coils. I could light a led with one of the coils but not with the other, and I have tested the wires close to the motor, so I believe it must be a damage inside the motor. There was also resistance difference.
    I have another new larger motor: 57BYGH78-401B 1.8 degr. 2.8A 1.8 N.m. Do you think I can use that with the Gecko driver? And do you know where I can buy a new driver for best price?
    Edit:
    I used the 8 wire motor in serial connection with the red/yellow and black/orange wires shorted and after cutting of these wires, the motor runs more smoothly and I got a light on the led at that coil that didn´t light before. When I short the red/yellow wires, the same problem occurs, so I found that the motor is wired with wrong colours compared to the specification at http://www.kelinginc.net/KL23H51-24-8B.pdf
    I have found that the red/yellow and green/blue are connected to each of the coils and my problem is now to find out which of them are a+ and a- ...
    Mar 2007
    2083
    if this is how the motor is connected
    Attachment 412082
    the motor should work
    unless your following instructions to make one of a number of identical machines
    swapping A+ and A- or B+ and B- will reverse the direction of the motor
    easily corrected in software if your using Mach 3 or similar to avoid resoldering the wires
    just make sure you don't mix the A and B wires
    John
    May 2006
    309
    That´s how it was connected, but when I connected the red and yellow wires together, it made a shortcut to one of the coils because these wires are the end wires of that coil on my motor. So I assume that my motor is wired with faulty colors compared to the wiring diagram which may have been caused by poor workmanship at the factory.
    Edit:
    I have tested the wires again and found that the two coils with red, blue, yellow and green wires all interacts with two other wires, so there must be a shortcut between the coils inside the motor which means that the motor is damaged. So I have to give it a try with the other larger sized motor.
    May 2006
    309
    After changing to a new motor and new driver, I got the motor to run but with a very strange sound (like fast ticking). When I tried to tune the pot on the driver in order to fix it, it looks like something went wrong and the force to the motor died and both the green and red leds are lighting on the G540 box. I pulled out the wire to the motor, but the red light is still on. The 3 other motors works normally.
    Mar 2007
    2083
    going by the circuit diagram for an early version of the G540 that I found in an old post on cnczone
    Attachment 412450
    I don't see how 3 axis can work with the RED led on
    as the enable signal to the G250 driver boards is used to switch between the red & green LED
    what happends if you remove the faulty G250 driver ?
    I guess its possible is pulling the enable signal down so there is a voltage across the red LED as well as the green LED
    are you sure the motor was connected correctly ?
    I would email or call Geckodrive.com
    John
    May 2006
    309
    I´m not sure but do you think it will be possible to get a motor to run in both directions if it´s wrong connected? I will try to remove the driver later and see what happens then.
    Mar 2007
    2083
    some times when a stepper motor is wired incorrectly
    at first glance it will look like its working
    you would hope the motor conforms to a standard colour coding of the wires
    assuming the new motor is another 8 wire motor like the KL23H51-24-8B
    Attachment 412462
    then you could have odd results if you either mix the pairs of coils
    for example connecting the red/blue coil to the brown/black coil and
    yellow/green coil to the orange /white coil
    wiring two coils in anti-phase
    for example connecting blue and yellow together and red & green to the driver
    would have dramatically reduced the inductance to less than the minimum 1mH
    resulting in an over current
    John
    May 2006
    309
    The new 57BYGH78-401B stepper motor was a 4 wired bipolar motor. I connected it wrong by connecting the -a to +a and visa versa, and did the same with the b wires, so I didn´t get the motor to run before I changed the settings in the Mach software. Is it possible to overload the drivers that way? Could I have done something wrong in the settings? The motor is rated with a current at 2.8A, so I mounted a 2.7 kohm resistance to the plug pins.
    I have now connected a new driver and now only the green led is on, but I´m afraid to try again with the same motor before I know what it was that failed.
    Mar 2007
    2083
    swapping A+ with A- and vise versa and / or B+ with B- and vise versa is not going to damage the driver
    just change the direction the motor turns if you swap one pair of wires
    a 2K7 resistor is close enough as it will set the motor current to 2.7A
    the problem is if you connect A+ to B+ and A- to A- for example
    if you get the mach3 settings wrong your not going to damage the driver but its possible to step too fast and stall the motor
    so far I have not found the 57BYGH78-401B data
    with a multimeter set to ohms you should be able to test the motor to find the two pairs of wires
    John
    May 2006
    309
    I didn´t connect a to b, but I´ve found that maybe one of the wires had a loose connection. Could that be a possible reason?
Page 1 of 2 12
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. G540 fault light...what does that mean?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 03-07-2011, 02:37 AM
  4. GECKO G540 - Stuck in "FAULT" mode.. HELP!?!
    By CNC74 in forum Benchtop Machines
    Last Post: 02-06-2010, 09:37 AM
  5. New member with a "Fault Light" question.
    By kweitz in forum Community Club House
    Last Post: 09-05-2009, 04:32 PM
