586,070 active members*
3,629 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Servo is randomly changing direction
Results 1 to 7 of 7
    Dec 2017
    34
    I'm just setting this up. Everything seemed to be working fine. Until it wasn't.
    When I jog either up or down, I don't know which direction the motor is going to turn.
    This is a Nema 34 with 8 wires. I'm using the Probotix Unity M Box with UCNCC software and a UC100 controller.
    I got the Probotix for $200 off over christmas.
    I've been scouring the forums, and can't find anything about this.
    Bruce
    http://www.heavymetalcnc.com
    Dec 2005
    596
    Re: Servo is randomly changing direction
    A servo or a stepper motor?
    Jun 2010
    4256
    Sounds like a stepper to me!
    If it was a servo it would sound as though you have a loose connection somewhere on the Dir line. I am not sure whether that is even possible with your stepper controller, but it might be.
    Failing the Dir line, you might, possibly, have a loose connection on one of the motor windings.
    In any event, it does sound like a loose connection somewhere.
    Cheers
    Roger
    1943
    Many drivers require a delay between setting the direction pin and the step pulses otherwise the motor could move in the wrong direction. This should be set in the control software.
    Could also be a loose dir in connection, or a bad cable.
    Dec 2017
    34
    Thanks for the replies to my misquote. It is a stepper motor.
    And the whole cable was bad, which is why I couldn't find it.
    ger21, thanks for making the light bulb go off, that was about the only thing I hadn't checked.
    A wire was broken in their somewhere when I put the meter on it.
    Jun 2015
    943
    This is why I always advice to MEASURE. But of course first you have to know what to measure.
  1. input pins changing status randomly
    By Wdwkr53 in forum Uncategorised WoodWorking Machines
    Last Post: 10-13-2017, 04:48 PM
  2. Y axis moves randomly in a direction
    By HansD in forum DIY CNC Router Table Machines
    Last Post: 07-30-2014, 11:43 AM
  3. Direction keeps changing
    By jjacstcy in forum DIY CNC Router Table Machines
    Last Post: 05-07-2011, 09:06 PM
  4. Keling 425oz/in randomly reversing direction??
    By mulligan in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 11:15 PM
  5. A3977/Mach3 Direction changes randomly
    By kiltjim in forum Open Source Controller Boards
    Last Post: 12-09-2007, 03:04 AM
