586,036 active members*
3,620 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Servo is randomly changing direction
Results 1 to 7 of 7
    Dec 2017
    34
    I'm just setting this up. Everything seemed to be working fine. Until it wasn't.
    When I jog either up or down, I don't know which direction the motor is going to turn.
    This is a Nema 34 with 8 wires. I'm using the Probotix Unity M Box with UCNCC software and a UC100 controller.
    I got the Probotix for $200 off over christmas.
    I've been scouring the forums, and can't find anything about this.
    Bruce
    http://www.heavymetalcnc.com
    Dec 2005
    594
    Re: Servo is randomly changing direction
    A servo or a stepper motor?
    Jun 2010
    4256
    Sounds like a stepper to me!
    If it was a servo it would sound as though you have a loose connection somewhere on the Dir line. I am not sure whether that is even possible with your stepper controller, but it might be.
    Failing the Dir line, you might, possibly, have a loose connection on one of the motor windings.
    In any event, it does sound like a loose connection somewhere.
    Cheers
    Roger
    1943
    Many drivers require a delay between setting the direction pin and the step pulses otherwise the motor could move in the wrong direction. This should be set in the control software.
    35538
    Could also be a loose dir in connection, or a bad cable.
    Dec 2017
    34
    Thanks for the replies to my misquote. It is a stepper motor.
    And the whole cable was bad, which is why I couldn't find it.
    ger21, thanks for making the light bulb go off, that was about the only thing I hadn't checked.
    A wire was broken in their somewhere when I put the meter on it.
    Jun 2015
    943
    This is why I always advice to MEASURE. But of course first you have to know what to measure.
  1. input pins changing status randomly
    By Wdwkr53 in forum Uncategorised WoodWorking Machines
    Last Post: 10-13-2017, 04:48 PM
  2. Y axis moves randomly in a direction
    By HansD in forum DIY CNC Router Table Machines
    Last Post: 07-30-2014, 11:43 AM
  3. Direction keeps changing
    By jjacstcy in forum DIY CNC Router Table Machines
    Last Post: 05-07-2011, 09:06 PM
  4. Keling 425oz/in randomly reversing direction??
    By mulligan in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 11:15 PM
  5. A3977/Mach3 Direction changes randomly
    By kiltjim in forum Open Source Controller Boards
    Last Post: 12-09-2007, 03:04 AM
