586,121 active members*
3,675 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX4660 and Mach3 Loader
Results 1 to 2 of 2
    Mar 2016
    3
    I setup Mach3 on a XP Home computer (it has necessary requirements for Mach3-fresh install of XP Home SP3). When I go to open the MX4660 profile, it freezes my computer and I have to power it down. If I go to load Mach3 Mill, it opens without issue.
    I was running Mach3 on a laptop with a TB6560 board, so as a test, I put the MX4660 XML file in Mach3 folder and it loaded there just fine...
    Any suggestions as to the problem?
    35538
    Re: MX4660 and Mach3 Loader
    Corrupt .xml file.
    Very common with Mach3.
    Always make a backup when you have everything working properly.
  1. Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    By pilotarix in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2022, 06:46 AM
  2. Spindle Relay Control with Mach3 and MX4660
    By icecats in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2017, 12:29 PM
  3. CNC Plasma table with MX4660, Mach3 and ESS
    By asuratman in forum Leadshine
    Last Post: 12-28-2016, 11:16 AM
