586,072 active members*
4,691 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Wiring VFD to motion controller
Results 1 to 6 of 6
    Mar 2018
    Hi guys - I need som help please
    My Chinese 9060 3-axis CNC router was born with a parallel port and NC Studio software, but now I am working my way through the process of upgrading to Mach3 with an ethernet motion controller.
    I'm pretty new in the CNC-world and now facing the problem of how to connect the VFD to the new motion controller without breaking something
    The VFD is a Sunfar 2.2kw, model E300-2S0022
    The motion controller is a XHC MK3-ET-T4S (V5.41)
    I've attached images from the manuals:
    Any help is appreciated
    Dec 2003
    24221
    Re: Wiring VFD to motion controller
    No experience with either but looks OK to me on the surface.
    At least it doesn't look like you would do any damage to try.
    Al.
    Albert E.
    Mar 2018
    Thanks for replying, Al
    I have made a quick sketch showing the wiring, but I'm not sure if it correct
    Can anyone confirm that the wiring is correct?
    Thanks in advance.
    35538
    As Al said, it looks right, but I've never used either of those devices either.
    Dec 2018
    5
    Quote Originally Posted by LalloMan View Post
    Hi @lalloman. Were u able to get over with ur problem about xhc mk3? Im looking for a controller and some friends suggested me this model (ethernet version). Is it worth to buy it?
    15362
    Looks all correct Just check the control output FWD and 0V don't have any voltage and that it is just a switch/Relay switching
    Mactec54
  1. Replies: 4
    Last Post: 04-18-2024, 11:10 AM
  2. Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
    By MartinBarfoed in forum Stepper Motors / Drives
    Last Post: 04-02-2019, 11:50 PM
  3. Z Axis auto zero plate wiring on usb motion controller
    By phongshader in forum Chinese Machines
    Last Post: 11-10-2017, 02:01 AM
  4. Replies: 0
    Last Post: 09-17-2013, 05:38 PM
  5. e-stop wiring for a JMAR Precision motion controller?
    By josh591 in forum Servo Motors / Drives
    Last Post: 04-17-2009, 07:06 PM
