586,051 active members*
3,627 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Enable parameter writing parameter 6219
Results 1 to 6 of 6
    Jan 2010
    6
    I have a Hitachi Seiki HT40 lathe with Seicos Multi Interactive control. I am trying to adjust the X axis backlash. I need to enable parameter 6219 by changing from a zero to a 1. It will not change. It appears I have to set a rotary switch on the main circuit board of the control to allow this change to happen.
    I do not have a maintenance manual showing the correct setting to do this. Any ideas?
    Bud
    Dec 2009
    539
    Re: Enable parameter writing parameter 6219
    Bud,
    You shouldn’t have to rotate the switch. As long as you have the parameter write under the SET menu enabled and you’re in MDI mode it should work for backlash settings.
    Let me know (Assuming this is i80 multi)
    John
    Jan 2010
    6
    I did not try to search down under the Set tab. I was looking in the PRM tab. I will give it a try.
    Jan 2010
    6
    Quote Originally Posted by BAFJB View Post
    I did not try to search down under the Set tab. I was looking in the PRM tab. I will give it a try. I tried changing 6219 under the SET tab and it worked great..
    Bud
    We have a selection of manuals for Hitachi Seiki machines including maintenance manuals and parameters.Visit www.cybermachinerysales.com
    Oct 2019
    I have a Hitachi Seiki HT40 lathe with Seicos Multi Interactive control. I am trying to change control from inches to metric.
    I do not have a maintenance manual showing the number of parametr to do this. Any ideas?
  1. Can't enable TSC parameter
    By Ydna in forum Haas Mills
    Last Post: 03-26-2017, 07:00 PM
  2. Fanuc 6mb parameter 600-603 writing problems
    By serickson in forum Fanuc
    Last Post: 01-05-2015, 02:59 PM
  3. parameter to enable auto operation with edit key on??
    By chris.spencer in forum Mori Seiki lathes
    Last Post: 07-24-2014, 03:31 PM
  4. Replies: 3
    Last Post: 06-25-2012, 08:20 PM
  5. Mazak EIA enable parameter
    By Bakes1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2008, 08:17 PM
