586,403 active members*
2,657 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 500w chinese spindle interference
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    ericks Guest
    Re: 500w chinese spindle interference
    Quote Originally Posted by GreenCameleon View Post
    Ok, I did the test. This time no incidents. I started with a slow speed on the spindle and gradually increased its speed to max. The issues with the LCD are still present, when the spindle is turned to more than 60% of its power. Also ordered a screened cable, which I'll replace with the existing spindle wires, as suggested by Johnboy251.
    Sorry to hear about your trouble...sorting these issues can be a real challenge specially the lcd
  2. #42
    Jun 2018
    19
    Quote Originally Posted by ericks View Post
    Thank you. Luckily, the are a lot really awesome and patient people on this forum, who are willing to guide you trough the troubleshooting process and will give you additional advice. Hopefully these issues will soon be resolved.
  3. #43
    Jun 2019
    I had the same problem with noise on Arduino and 500 watts Chinese spindle. My Arduino went into panic mode and more so at higher RPM
    Here is a video it is in Spanish but i am in the process of finishing one in English, if you fast forward the 13:40 mark i got a clip of the filter network.
    here is a link where the RC FILTER schematic. https://github.com/gnea/grbl/wiki/Wiring-Limit-Switches
    I must say, that the filter made it better but from time to time I would get interference so i ended up installing FERRITE BEADS to every input of the Arduino (limit switches etc) also on the AC line, speed control wires and Spindle output wires. The spindle control (power supply) is mounted to the machine frame and the machine frame is grounded to EARTH ground (AC)
    My 500 watts Chinese spindle is very quiet but i am experiencing a lot of chatter when cutting aluminium. I guest I have to come up with the right settings.
  4. #44
    May 2007
    15
    I have done some measurements on the spindle pwm supply.
    measurements are done with a cheap multimeter.
    Relay is the start / stop of the spindle.
    The potm. is internal connected with the + voltage spindle
    Attachment 425234
    Most funny thing is the PWM, measured with a 20$ DSO.
    Voltage on the screen has to be multiplied with 10x due to the probe.
    Attachment 425236
    the indicated PWM is 15% - 18.4% and 23% at 23% the spindle is running 10.000 rpm.
    I think the wave form give a lot of interference.
  5. #45
    Jan 2017
    Hi I am thinking of buying that 500W Chinese spindle also.
    Aside from the noise problem, does it work?
    Bearings noisy/vibration? Sufficient power?
    Thanks.............dd
  6. #46
    May 2007
    15
    @ddlawrence
    I have not done any job with this spindle. With the potmeter, rpm adjustment is OK . A problem is the rpm adjustment with 0-10V (is not a big problem) . This is a spindle with carbon brushes, I have the idea that a BLDC spindle gives less interference problems and later no problems with carbon brushes.
    The power you need, depends on the feed and speeds and the size of the mill. Looks like the Shapeoko 102-2 has one, just look at you tube. To use this spindle all your cables has to be shielded. This is a spindle for the low end machines and it works, it runs OK no vibrations not so noisy.
  7. #47
    Quote Originally Posted by hex173 View Post
    Attachment 425234
    Attachment 425236
    Hi... Why is one side of the speed control potentiometer connected to the ‘+’ (plus) side of the motor? Does this say this in the drive instructions?
    This doe’s look right...
    Sent from my iPad using Tapatalk
  8. #48
    May 2007
    15
    I have measured the volts. So between + 80V and the brown wire is measured 0 V and between the orange wire and +80V is measured 83.4 V
    Verstuurd vanaf mijn SM-T580 met Tapatalk
  9. #49
    May 2007
    15
    Ah, now I see your problem. The connection is not there, it is only drawn to show that the connection must be inside, due to the measurements. You do not have to make this connection. You are right it is not clear.
Page 3 of 3 123
  1. Upgrading my 3040 with a 500W spindle (replacing the 300W one)
    By MustangviennA in forum Chinese Machines
    Last Post: 01-31-2019, 11:53 PM
  2. 500 watt DC spindle creates interference on arduino
    By Alectro in forum Spindles / VFD
    Last Post: 09-26-2018, 10:53 AM
  3. Power 500W Spindle from 1/5kW VFD
    By ajayre in forum Spindles / VFD
    Last Post: 08-12-2018, 12:24 PM
  4. Spindle Limit Switch Interference
    By Macca05 in forum Spindles / VFD
    Last Post: 06-29-2018, 02:16 PM
  5. Replies: 6
    Last Post: 02-04-2014, 10:50 PM
