586,104 active members*
3,213 visitors online*
    Jun 2005
    84
    TL Lathe Tailstock Rigidity
    I have a TL-2 lathe with a side clamp style tailstock like the picture below.
    https://520machinery.com/2007HaasTL2_01232012-2.jpg
    It has a lot of deflection in it. I can push it by hand when locked so it deflects at the top by 0.002" or so. It also squeezes the rails together about 0.005" when clamping and obviously doesn't repeat well that way. I can machine anything over 24" long without major chatter at the end. Is this normal for this setup. I realize the design has clanged a few times over the years. Mine is a 2006.
    I am considering making a new base and use the Bosch bearing blocks, however I am wondering how much better that is? Or is it a lack of rigidity in the rails themselves? If anyone has a newer lathe with preloaded bearings in the tailstock I would love to know how ridged it is?
    Thank you in advance.
    Will
    Dec 2013
    5717
    Re: TL Lathe Tailstock Rigidity
    Looks like poor design to me. The entire mounting system does not provide much lateral support, hopefully the newer machines have a more robust design. The tailstock should be as rigid as the headstock.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2008
    1632
    Did you come up with anything on your tailstock?
    I have a 2005 and turn lots of 15-18" SS shafting and setting the tail stock sucks. Once I get it set, I leave the power on during the entire time so I don't have to move the tailstock to home.
    I typically just get it as close as I can then use a U0.00x to take the taper out. It typically takes a few cuts to get it just right but it's lots of wasted time. I thought about putting it on bearing blocks, but I don't think there would be a good way to lock it down.
    Quote Originally Posted by will_eng View Post
    Will
  1. Replies: 0
    Last Post: 07-27-2016, 10:42 PM
  2. 9x20 Lathe Tailstock.
    By Dougal in forum Benchtop Machines
    Last Post: 09-10-2010, 12:58 PM
  3. Getting CNC lathe tailstock to move
    By lkenney in forum MetalWork Discussion
    Last Post: 02-12-2009, 11:02 PM
  4. Looking to buy a CNC lathe w/ tailstock
    By Buildm1 in forum Want To Buy...Need help!
    Last Post: 12-15-2008, 07:10 PM
  5. Drilling on Lathe without tailstock
    By NJC in forum MetalWork Discussion
    Last Post: 11-07-2008, 03:55 PM
