586,103 active members*
3,813 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > BP 720 Interact with Y-axis drift when in programmatic cutting
    May 2006
    60
    Hello All,
    I am having problems with my 1989 Bridgeport interact 720 with Heidenhain 351/355 controller.
    After two years cleaning and rebuilding and creating a fusion 360 post, I think I have found why the machine was for sale in the first place.
    When programmatic cutting the Y-axis is drifting at a constant rate, you can see on the screen Y changing, yet If I just manually make a cut it is square and Y does not change.
    Here is a picture show the problem, the first arrow is showing the drift and the second is showing a manual cut that is square.
    Any ideas?
    Thanks, Bryan
    Attachment 412548
    May 2006
    60
    720 Update
    When I was making some more test cuts in the air yesterday and found out it is also drifting in the X direction when cutting in the Y only axis. It will cut a square but not parallel to the table.
    Is there machine parameters that may be wrong or need to set to fix this problem?
    Video's showing movement in the X direction only, Y only, and a 90 angle. I did my best to sync the include screen information.
    In each case, the first file is a video and the second is .h control file. I included the .h file.
    Move X
    Dropbox - Move X.mov
    Dropbox - 5004.h
    Move Y
    Dropbox - Move Y.mov
    Dropbox - 5005.h
    Move 90
    Dropbox - Move 90.mov
    https://www.dropbox.com/s/xc3duikp4ofbofl/5006.h?dl=0
    Any ideas on how I might fix this is greatly appreciated.
    If you need more information about the machine or need me to do a test please just ask.
    Bryan
    May 2006
    60
    Re: 720 problem ROT fixed
    Hello All,
    So the real question was, what can supersede other commands.
    Wait for it..... The Touch Probe
    Press Touch Probe
    Up arrowed to Rotation ent
    It was set +2.0 degrees, pressed 0, ent
    ROT disappeared... and this problem is put to bed.
    Video of fix
    https://www.dropbox.com/s/stc6n4c2tm...20res.mp4?dl=0
    Thanks for your help,
    Bryan
  1. Z Axis Drift......
    By bbristow in forum DIY CNC Router Table Machines
    Last Post: 02-22-2016, 11:10 PM
  2. Axis Drift, Need Help
    By Evanrigs in forum Uncategorised CAM Discussion
    Last Post: 05-07-2014, 07:53 PM
  3. Axis Drift HELP!
    By ppollioni in forum Open Source CNC Machine Designs
    Last Post: 04-22-2012, 02:35 PM
  4. Y axis drift
    By japco43 in forum Controller & Computer Solutions
    Last Post: 02-23-2011, 09:01 PM
  5. Z axis drift
    By IainLGrant in forum Benchtop Machines
    Last Post: 03-12-2006, 02:56 PM
